lowering springs!!i have a question.
i was just wondering,im getting new rims size 16 with 205/45/16s and im lowered 2.5 inches.i was just wondering if my car will drop a little bit once i put these new rims on.thanks guys.
I hate everything
Yeah, if you put on bigger tires then your stock one, you'll notice a smaller gap between the fender and the wheel.
When I took off my 17"s, and put on my snow tires, I think there 14"s? The gap between the fender and the wheel increased.
Trust me, with 16"s w/ a 2.5 drop, it will look good.
hth
hth
The difference will be insignificant. Stock tire size is 195/55/15, and your putting on 205/45/16, which is pretty much the same size. I believe its a .01% difference or something like that. Look for a tire size calculator and put your current size in and put your new size in and compare the outer diameter size.
Ali
Edit: Since i'm bored:
Stock 195/55/15
Diameter 23.4 in
Circumfrence 73.7 in
New 1: 205/45/16
Diameter 23.3 in
Circumfrence 73.1 in
New 2 205/40/16
Diameter 22.5
Circumfrence 70.5 in
New 3: 205/40/17
Diameter 23.5 in
Curcumfrence 73.7 in
New 4: 195/50/15
Diameter 22.7 in
Circumfrence 71.2 in
And here's the link; http://www.miata.net/garage/tirecalc.html
Ali
Modified by PrinceAli132 at 10:06 PM 12/28/2005
Ali
Stock 195/55/15
Diameter 23.4 in
New 1: 205/45/16
Diameter 23.3 in
New 2 205/40/16
Diameter 22.5
New 3: 205/40/17
Diameter 23.5 in
New 4: 195/50/15
Diameter 22.7 in
Ali
