Soldering oxygen sensor wires
Old Dec 28, 2005 | 03:45 PM
Achenar's Avatar
Default Soldering oxygen sensor wires
What are people using to solder their O2 sensor wires?
I have some unknown-brand solder, and it simply does not form a bead on the O2 sensor wires. It works great for just about every other wire I've ever attempted to solder. But it drips off like water from the O2 wires!
-a
Old Dec 28, 2005 | 04:08 PM
Achenar's Avatar
Default Re: Soldering oxygen sensor wires (Achenar)
Scratch that, this is the solder I am using, and it is definitely not pulling
Old Dec 28, 2005 | 04:37 PM
T-RO's Avatar
I get solder at Radio Shack and have never had a problem
Old Dec 28, 2005 | 05:24 PM
Padawan's Avatar
Darth ModerVader
It seems more like a problem with the soldering iron/gun than with the solder itself. What you're describing sounds as if the wire isn't being heated to a high-enough temperature to allow the solder to properly melt and flow.
Old Dec 28, 2005 | 06:24 PM
Achenar's Avatar
Default Re: Soldering oxygen sensor wires (Padawan)
I thought so too. Which is why I went from a 15 watt iron to a 150 watt gun.
Either I'm still not heating up the wires enough, or these wires require some insane amount of wattage.
-a
Old Dec 28, 2005 | 06:37 PM
Padawan's Avatar
Darth ModerVader
I don't see why the wires would require an exceptional soldering gun. Since you already upgraded the equipment and are still having difficulty, it certainly couldn't hurt to stop somewhere like Radio Shack or your local hardware store to pick up some new solder (possibly smaller diameter).
Old Dec 28, 2005 | 06:40 PM
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote"> (possibly smaller diameter). </TD></TR></TABLE>
that's what I was going to suggest.
Old Dec 28, 2005 | 06:49 PM
freakin_eLRoD's Avatar
try putting some soldering flux on it. the flux acts as a heat transfering agent and allows the solder to melt evenly across whatever your soldering
Old Dec 28, 2005 | 07:03 PM
RCautoworks's Avatar
I have had the problem before, it just takes more heat and more time. Maybe because the wires are not copper ? Copper retains heat better, just a though.
Old Dec 28, 2005 | 08:04 PM
EK k kay's Avatar
Default Re: Soldering oxygen sensor wires (90blackcrx)
I used Radio Shack solder. Worked fine.
Old Dec 28, 2005 | 09:33 PM
LShatchie's Avatar
Default Re: Soldering oxygen sensor wires (EK k kay)
radio shack solder
Old Dec 28, 2005 | 10:12 PM
DC4KiD's Avatar
Default Re: Soldering oxygen sensor wires (LShatchie)
Flux/Flux paste is your best friend when it comes to soldering
Old Dec 30, 2005 | 09:17 PM
dornon13's Avatar
Default Re: Soldering oxygen sensor wires (DC4KiD)
get the thinnest solder you can find and you will be super happy...i have a huge roll or this tiny stuff and its sooo much easier flux works well too
blindsk8er1013
Sep 16, 2008 04:38 PM
Hellnoitsalex
Dec 17, 2007 03:34 PM
runitup
May 2, 2004 10:02 PM
94si94cx
Apr 30, 2003 03:59 PM
