what next on the 99 lude
Old Dec 28, 2005 | 03:09 PM
RC's ride's Avatar
Default what next on the 99 lude
hey i just picked up a grand for the lude and can't decide what to get. here are my mods i/h/e findanza flywheel, stage3 clutch,manual tensioner an no balance belt . I was thinking of a p28,hondatas200 and tune or the ssautocrap turbo and chip tune a p28 .Now i know this is not the best way go but it could be done and fine tune it along the way with future upgrades. n/a is nice but a long road and an average turbo will put you in the mid 14s .I'd really like to go n/a but with my mods how far away am I from a low 14s car. I'm guessing 3000 dollars. But anyway 1000 how would you spend it???
Old Dec 28, 2005 | 05:03 PM
BB6-213's Avatar
I would spend it on suspension or cosmetics, because unless you have a solid $3000 to turbo it correctly, I wouldnt jump into it.
Modified by BB6-213 at 7:26 PM 12/28/2005
Old Dec 28, 2005 | 05:05 PM
R.a.w.'s Avatar
Default Re: (BB6-213)
you need proper suspension man. Youll see how important it is. If you already have that, than i would suggest a proper header. If you already have that than you can save up for a jun cams in my opinion and then tune away.
H23 Power's Avatar
you should be able to run mid 14's with your mods in a 5-spd 5th gen.
Old Dec 28, 2005 | 05:53 PM
RC's ride's Avatar
Default Re: (H23 Power)
well I haven't been to the track sence the mods where done but I think i'd be lucky to hit a 14.9... I've got neuspeed springs and front and rear strut bars sittin on a set of polished subzero's... I could use some shocks but I want more power...has any one out there used one of these ssautocrome turbos and what were the results...my boy's are junk yard turboing there civics and putting down nice #'s...I know the h22 is a defferent breed but i'm thinking 5 psi and a moderate tune on a p28 couldn't it hang till i get injectors and hondata... or maybe not ... the easy way out is a p28,hondata,a collector mod and tune but not as sweet as the turbo oh well ...WHATS THE VERDICT???
Old Dec 28, 2005 | 07:57 PM
AP1's Avatar
AP1
yeah your good for low to mid 14's if you can drive with your current setup. Don't waste your time turboing the H series. I don't give a rats *** what anybody tells you, the motor was meant for N/A - leave it how Honda intended it to be built.
Old Dec 28, 2005 | 08:47 PM
RC's ride's Avatar
Default Re: (mikeiswaydope)
alright lets say n/a 1000...p28,uberdata,collector mod,aem pulley's..would upgrading the injectors and fuel rial help or a walbro fuel pump...what do you guyz think on the fuel situation???
Old Dec 28, 2005 | 09:25 PM
DIRTYsouthBB6's Avatar
Default Re: (RC's ride)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RC’s ride &raquo;</TD></TR><TR><TD CLASS="quote">alright lets say n/a 1000...p28,uberdata,collector mod,aem pulley's..would upgrading the injectors and fuel rial help or a walbro fuel pump...what do you guyz think on the fuel situation???</TD></TR></TABLE>
Your stock fuel system is good for way more power than you're making... high-flow fuel components can't hurt, but they won't do anything for you unless your current ones are bad.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RC’s ride &raquo;</TD></TR><TR><TD CLASS="quote">I know the h22 is a defferent breed but i'm thinking 5 psi and a moderate tune on a p28 couldn't it hang till i get injectors and hondata... or maybe not ... the easy way out is a p28,hondata,a collector mod and tune but not as sweet as the turbo oh well ...WHATS THE VERDICT???</TD></TR></TABLE>
Rushing your install and purchase of products, and hoping that " it will hang " until you get enough money to complete the job the correct way is a very good way of digging yourself into a money hole and learning a very blatantly-hard lesson.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H23 Power &raquo;</TD></TR><TR><TD CLASS="quote">you should be able to run mid 14's with your mods in a 5-spd 5th gen.</TD></TR></TABLE>
I think he said that he has an automatic
Old Dec 29, 2005 | 12:04 AM
vinuneuro's Avatar
Default Re: (DIRTYsouthBB6)
Sticking with just bolt-ons:
-Suspension
-Good header
-Tune
Old Dec 29, 2005 | 12:40 AM
RATED EG's Avatar
Default Re: (vinuneuro)
did i miss something? why do you have a stage 3 clutch?
i'd buy tires and a header. or just a header.
Old Dec 29, 2005 | 09:06 AM
RC's ride's Avatar
Default Re: (RATED EG)
Alright complete mods list (aem intake ,megan header,test pipe,apexi n1,findanza fly wheel,xtd stage 3 clutch,denso iradium plugs,nuespeed springs,strut tower bars,rota subzeros on new proxes... lets go n/a MORE POWER MORE POWER MORE POWER!!!!!!!
Old Dec 30, 2005 | 10:01 AM
RC's ride's Avatar
deffinately getting tuned .what else
Old Dec 30, 2005 | 10:07 AM
The Phil's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RC’s ride &raquo;</TD></TR><TR><TD CLASS="quote">Alright complete mods list (aem intake ,megan header,test pipe,apexi n1,findanza fly wheel,xtd stage 3 clutch,denso iradium plugs,nuespeed springs,strut tower bars,rota subzeros on new proxes... lets go n/a MORE POWER MORE POWER MORE POWER!!!!!!!</TD></TR></TABLE>
Oy.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikeiswaydope &raquo;</TD></TR><TR><TD CLASS="quote">yeah your good for low to mid 14's if you can drive with your current setup. Don't waste your time turboing the H series. I don't give a rats *** what anybody tells you, the motor was meant for N/A - leave it how Honda intended it to be built. </TD></TR></TABLE>
So Honda designed the B series to be turboed? Pull your head out of your ***.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RATED EG &raquo;</TD></TR><TR><TD CLASS="quote">did i miss something? why do you have a stage 3 clutch?
i'd buy tires and a header. or just a header. </TD></TR></TABLE>
So it doesn't slip once the immense torque from the uh......the uh......whatever.
Old Dec 30, 2005 | 11:00 AM
Drag_On's Avatar
A GOOD header (dont waste money on collector mod for Megan)... Get an RM-F header and get Hondata and have it tuned.. RMF header can be had for $600, pick up a used Hondata and then tune it.. You will net more whp than adding AEM pulley's and other crap.
Old Dec 30, 2005 | 07:17 PM
RC's ride's Avatar
Default Re: (Drag_On)
600 is cheap for an rmf aren't they like 700 to 800..I blow a load everytime I see one!!!
Old Dec 30, 2005 | 09:43 PM
SilverPanda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RC’s ride &raquo;</TD></TR><TR><TD CLASS="quote">600 is cheap for an rmf aren't they like 700 to 800..I blow a load everytime I see one!!! </TD></TR></TABLE>
800. yeah i'd go RMF and tune most hp for 1000 IMO.
nova55
31
Mar 11, 2010 09:13 AM
cavscoutnjtx
Nov 10, 2008 11:14 AM
JDM KID 510
Jan 3, 2006 08:24 PM
Osokwik
17
Mar 11, 2004 12:23 PM
XIntegraX
Jan 5, 2003 07:47 PM
