my brakes smoke after a spirited drive around the block!
Old Dec 28, 2005 | 02:51 PM
.Manny.'s Avatar
Touching My Member
Default my brakes smoke after a spirited drive around the block!
i have a 90 hatch si with rotora slotted disk and aem pads on stock calipers.
The last two times i have driven it i have come home and the left side has been smoking. I'm thinking the flat black paint on the steelies could be the problem because its just regular spray paint.
What else can it be guys, the brakes arent glowing or anything and its just on the left side. help please!
Old Dec 28, 2005 | 02:57 PM
temp's Avatar
Default Re: my brakes smoke after a spirited drive around the block! (90_EF_Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90_EF_Si &raquo;</TD></TR><TR><TD CLASS="quote">i have a 90 hatch si with rotora slotted disk and aem pads on stock calipers.
What else can it be guys, the brakes arent glowing or anything and its just on the left side. help please! </TD></TR></TABLE>
could be a caliper thats freezing up on you
Old Dec 28, 2005 | 03:00 PM
.Manny.'s Avatar
Touching My Member
could u explain a frozen caliper? sorry for the noob question.
the brakes feel normal and dont pull to one side when i brake hard. they seem fine mechanically.
Old Dec 28, 2005 | 03:07 PM
.Manny.'s Avatar
Touching My Member
bump
temp's Avatar
Default Re: (90_EF_Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90_EF_Si &raquo;</TD></TR><TR><TD CLASS="quote">could u explain a frozen caliper? sorry for the noob question.
the brakes feel normal and dont pull to one side when i brake hard. they seem fine mechanically.</TD></TR></TABLE>
hmmm....well if it doesnt pull to one side then its probably not a frozen caliper. have you taken the wheel off and examined the pad and rotor?
Old Dec 28, 2005 | 03:10 PM
.Manny.'s Avatar
Touching My Member
yeah they look fine, nothing out of the norm, could it be the paint, i sprayed the inside of the wheels too.
Old Dec 28, 2005 | 03:16 PM
.Manny.'s Avatar
Touching My Member
bumper
Old Dec 28, 2005 | 03:18 PM
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90_EF_Si &raquo;</TD></TR><TR><TD CLASS="quote">yeah they look fine, nothing out of the norm, could it be the paint, i sprayed the inside of the wheels too.
does the inside of the left wheel look odd? like any sort of paint disfigurement?
Old Dec 28, 2005 | 03:21 PM
.Manny.'s Avatar
Touching My Member
you know what, yeah, there is some paint thats all f-ed up in there, thanks a lot temp. i just looked at it, im hoping thats the end of it. if there are more problems i will be back, thanks again temp.
Old Dec 28, 2005 | 03:24 PM
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90_EF_Si &raquo;</TD></TR><TR><TD CLASS="quote">you know what, yeah, there is some paint thats all f-ed up in there, thanks a lot temp. i just looked at it, im hoping thats the end of it. if there are more problems i will be back, thanks again temp. </TD></TR></TABLE>
why not take some paint thinner to the f-d up paint and then take it for a drive, see if it smokes up still
JDMister_EF9
Sep 13, 2006 08:20 AM
HamandEGgs
Suspension & Brakes
Jan 10, 2006 07:33 PM
Mr.Speed
Apr 19, 2005 09:16 PM
sit220
16
Jul 27, 2004 10:24 PM
JLange
Sep 10, 2002 07:13 PM
