Replaced p72 with a P28 ecu Problem
Old Dec 28, 2005 | 12:53 PM
Guru Designs's Avatar
* B A N N E D *
Default Replaced p72 with a P28 ecu Problem
I recently purcheased a chipped p28 ecu for my gsr/itr setup. when i installed the ecu i removed the negative battery cable and removed the backup fuse then installed the ecu. i conencted the fuse then the neg cable then tried to start the car. it didnt start. i cranked it again and held the gas. it started but the main relay started clicking like MAD. and it would misfire and shut off. i removed the p28 and tried my p72 and it started fine. What could cause this problem a bad ecu? or maybe the chip in the ecu? thanks in advance
Old Dec 28, 2005 | 02:32 PM
tilt's Avatar
Default Re: Replaced p72 with a P28 ecu Problem (tobe2be)
What map is on the chipped p28?
Old Dec 28, 2005 | 04:00 PM
diversegsr's Avatar
Default Re: Replaced p72 with a P28 ecu Problem (tilt)
also are you running a jumper harness with the ecu...what year gsr??? ob1..ob2....
Old Dec 28, 2005 | 06:11 PM
* B A N N E D *
sorry using a mugen chipped obd p28 and i have a 94 gsr,
Old Dec 28, 2005 | 09:33 PM
milton's Avatar
Default Re: (tobe2be)
..hmmm knock sensor problem,? any codes?>
BIGGMIKEE
Texas -OK -LA (Sales)
Nov 4, 2010 02:58 PM
Jap_Spec_Imports
Oct 29, 2009 08:32 PM
Guru Designs
Dec 29, 2005 01:11 AM
sicilian2k1
Aug 5, 2001 11:06 PM
