3rd gen civic engine 1.5L carb'd
Old Dec 28, 2005 | 07:59 AM
D's Avatar
D
Default 3rd gen civic engine 1.5L carb'd
Checked FAQ, more than a few broken links.... searching for 'third' gen is useless.... any help appreciated.
Looking for info on a 86 wagon 4x4.. i'm presuming it has the same engine as the 84-87 CRX DX, carb'd 1488cc 12 valve, 9.2:1
Is the engine code D15A or EW1? or are they one in the same? Need to know if this is a D series, and i can exchange blocks with otther D series or additional info on the EW1/2 series longblocks.
Any direction appreciated.
D
Old Dec 28, 2005 | 09:17 AM
bagpipe goatee's Avatar
redpepperracing.com will give you more info than here. the engine is an ew1, but they changed the name to a d-series. it's not a normal d-series, though. the d16a1 out of the first gen integra will swap in, however i think you have to use the teg tranny, which won't like your 4wd. hasport sells b-series mounts for those cars, but they're like 500 bucks. it would be cool, though, to have a b-series with a crv manual tranny allowing you to keep 4wd.
Old Dec 28, 2005 | 09:50 AM
D's Avatar
D
Default Re: (bagpipe goatee)
Thanks!
so, is a d-series, but not really. hrm... any idea why i can't swap in a newer D-series block? actual bolt pattern on the bellhousing/block or crank/flywheel clutch issues?
CRV manual tranny's are next to impossible to find, and quite expensive when available....
Old Dec 28, 2005 | 11:16 AM
cchhrriiiss's Avatar
Default Re: (D)
Newer D-series will not swap in because the mounts are all in different locations. You could swap in a D15A3 which is out of the 84-87 Si but its Fuel injected and you would have to swap some stuff over. The D15A2 is in the Hf and Dx's and is Carb'ed. Heres a link for swapping in a newer D.
http://www.redpepperracing.com...20487
Old Dec 28, 2005 | 12:13 PM
D's Avatar
D
Default Re: (ChrisBrown)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChrisBrown &raquo;</TD></TR><TR><TD CLASS="quote">Newer D-series will not swap in because the mounts are all in different locations. </TD></TR></TABLE>
but newer D-series will bolt up to the 4x4 tranny in the 86 wagon, yes?
is this a comparable situation to the B20 in the early generation ludes vs. B18C/B20 blocks?
Old Dec 31, 2005 | 06:28 PM
Default Re: (D)
No way. The newer D-series engine will not bolt up to the older series tranny. Nothing really is compatible between the two, thats why everyone says its not really a D-series. The D15A3 is really the only option for a swap and it will bolt to the Awd tranny. You might wanna look into swapping in an Awd tranny out of an Ef wagon with a newer D-series.
Modified by ChrisBrown at 7:43 PM 12/31/2005
Old Dec 31, 2005 | 07:13 PM
silentdork818's Avatar
Default Re: 3rd gen civic engine 1.5L carb'd (D)
D16A1/ZC using stock 4wd tranny:
http://effinmotorworks.com/Zeno_Writeup.htm
Old Dec 31, 2005 | 11:48 PM
jeff420's Avatar
Default Re: 3rd gen civic engine 1.5L carb'd (silentdork818)
the d16a1 will bolt up to the 4x4 tranny. you cant use a regular civic or crx block, it has to be a 4x4 block or a d16a1.
Old Jan 1, 2006 | 01:00 AM
Default Re: 3rd gen civic engine 1.5L carb'd (jeff420)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jeff420 &raquo;</TD></TR><TR><TD CLASS="quote">the d16a1 will bolt up to the 4x4 tranny. you cant use a regular civic or crx block, it has to be a 4x4 block or a d16a1. </TD></TR></TABLE>
Yup
Old Jan 1, 2006 | 11:57 AM
Oh really? Care to elaborate. I didnt run into any problems.
Modified by ChrisBrown at 6:12 PM 1/1/2006
Old Jan 2, 2006 | 07:45 AM
davens's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silentdork818 &raquo;</TD></TR><TR><TD CLASS="quote">D16A1/ZC using stock 4wd tranny:
http://effinmotorworks.com/Zeno_Writeup.htm</TD></TR></TABLE>
^That's my swap. The wagons abilities have been reasonably improved. Its not the fastest car, but its a lot more fun than it was. There are some serious tranny differences between the 4wd and the 2wd versions of civics. As seen here, people insist they are not interchangeable but I've never had the two side by side to tell you why.
Before you look at a full swap, you should consider a carb upgrade(if your engine is in good shape). There are a lot of carb choices but I think the Webers are the best choice. There are like a million setups for whatever you want to do. They are well supported, reasonably priced and pretty easy to install compared to the stock setup.
The downdraft style offers a nice improvement in power and modest increases in mpg. If you want max power, the sidedrafts will offer impressive gains but usually at the expense of mpg.
You'll want to thoroughly learn about carbs before you tackle this...and Honda sites aren't much help. There is a carb subsection at Redpepper that is a good primer but still doesn't have all the answers.
I knew next to nothing about carbs when I started this...I used this book to help me get familiar with it all: http://www.amazon.com/gp/produ...83155
Old Jan 9, 2006 | 07:41 AM
D's Avatar
D
Default Re: 3rd gen civic engine 1.5L carb'd (davens)
Thanks for everyone's input.
Eventually I shall try and update this with some additional info. I currently have a D16A1 browntop, and will be pulling the stock motor out of the 86 wagovan when the weather breaks.
Thanks again.
D
hondaaccordf23
Oct 12, 2013 05:36 PM
V1ct0ri4
Oct 2, 2009 11:37 PM
GGM07FA
Honda Civic (2001 - 2005)
16
Apr 7, 2007 08:21 AM
stock00civic
Feb 10, 2007 07:20 PM
jmillheiser
Jan 4, 2004 02:29 AM
