Question about speedo on EDM cluster
Old Dec 28, 2005 | 05:33 AM
wickedEFguy's Avatar
Default Question about speedo on EDM cluster
My GF just bought me a EDM cluster for my CRX and what I wanted to do is keep the same mileage on my CRX.
So my question is this:
Is it easier to get a drill and just wait until I get to my desired mileage on the cluster or is the speedo part USDM/EDM interchangable?
Old Dec 29, 2005 | 09:51 PM
Deetz's Avatar
Crazy Honda Guy
A drill? Noooooo
All you gotta do is pop off the plastic cluster cover, remove 4 screwss from the back and the speedo come out, take a small piece of wire and wrap it around the needle base and pull up...swiftly, remove the 2 screws that hold the little cover over the speedo.
Then the little plastic tabs beside each of the numbers on the odometer, push it to the side a bit and press firmly on which ever number roll you want to change, make sure to roll forward.
Sounds like a lot, but its not. I can make any cluster read anything in about 4 mins flat.
teg_dc2
Sep 24, 2008 10:10 AM
suspendedHatch
Jan 22, 2007 07:42 AM
Bangers
Aug 30, 2006 12:15 AM
Sliced Beard
Aug 28, 2004 03:03 PM
bgod
Dec 17, 2002 10:53 AM
