Brake Booster Question
It is alright if I use a brake booster out of a abs integra as long as i use a non abs master cylinder right? Because my local junkyard has a 94 integra 2 door but i don't know the trim so much stuff is missing but the booster looks new let me know thanks.
someone told me the push rod in a abs booster is longer and will keep pressure on the master cylinder and over heat the brakes but it just doesn't sound right to me i think he is full of ****. but i don't want to take any chances
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mxpx035 »</TD></TR><TR><TD CLASS="quote"> i think he is full of ****. </TD></TR></TABLE>
i think your right
i think your right
correction .. the booster is not the same .. don't go out giving wrong advice man. i have personally tried gsr booster with rs m/c .. it bolts up but won't work .. the gsr runs a bigger booster with a longer push rod .. rs = 260nm-v and the gsr/ls/gs runs on a 290nm-v-2 .. do your reserach before you go out giving wrong advice .. people like you screw up honda-tech ..
