dc5 type r intake manifold: Worth it?
Old Dec 28, 2005 | 12:56 AM
teknoracing's Avatar
Default dc5 type r intake manifold: Worth it?
Ive seen these go from as low as $240 to as high as $350. I heard they go out of stock quickly as well. Are the gains really worth the price? Any difference in say installing it on a base model or a type s? There were a few threads on here that helped but nothing too concrete. IM sure with more mods as say upgraded cams the manifold would help out. I was also under the impression that the type s and type R TB are the same size.
Old Dec 28, 2005 | 10:17 AM
Default Re: dc5 type r intake manifold: Worth it? (teknoracing)
bump
Old Dec 28, 2005 | 05:55 PM
BlueTeg01's Avatar
Bump...opinons needed!
Old Dec 28, 2005 | 09:27 PM
NCNBPDC5's Avatar
Default Re: dc5 type r intake manifold: Worth it? (BlueTeg01)
there is no need for the type r mani unless you have bigger cams...our cars manis flow enough air for the stock cams...now if you plan to get cams in the future...then you will see some gain...
Old Dec 29, 2005 | 12:18 AM
Default Re: dc5 type r intake manifold: Worth it? (NCNBPDC5)
Of course, upgraded cams are a must, i was just asking if for the price it was worth it or are there other IM's that outflow this one for a better price
Old Dec 29, 2005 | 02:00 AM
Bluewind's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teknoracing &raquo;</TD></TR><TR><TD CLASS="quote">Of course, upgraded cams are a must, i was just asking if for the price it was worth it or are there other IM's that outflow this one for a better price</TD></TR></TABLE>
Yes, it's worth it. The gains are realized in the top end. As for the cost and options, you don't have anyother alternative. Your choices are either going with the prc, rbc/adaptor, itbs, or 75mm ihb im. Sounds like price is an issue, therefore stick with the prc.
Old Dec 30, 2005 | 01:06 AM
Default Re: dc5 type r intake manifold: Worth it? (Bluewind)
Price isnt the issue really, im sure no one else wants to buy something and waste their money on something that only creates mediocre power over stock. Thanks for the input though
Old Dec 30, 2005 | 02:58 PM
yeahi's Avatar
do you plan on rasing your rev limiter? Because if you don't, then theres' really no point in getting this im.
Old Dec 30, 2005 | 03:24 PM
Default Re: dc5 type r intake manifold: Worth it? (yeahi)
Still doing research on what to do, dont want to overwork the motor. I plan to dyno it and go from there.
Old Dec 30, 2005 | 05:55 PM
yeahi's Avatar
that motor can take a lot of abuse, you can raise the rev limiter slightly and it will be fine on stock stuff. the type-r manifold is developed for the extra rpm's the type-r revs to.
Old Jan 2, 2006 | 11:18 AM
Brillo's Avatar
Let the manifold be one of the last things you purchase. You need to be more concerned with saving for a supercharger or turbo set up.
Old Jan 3, 2006 | 01:02 AM
Default Re: (Brillo)
Thanks for all the input, im just really hoping someone will see this and post up a dyno sheet
Old Jan 3, 2006 | 12:30 PM
Bluewind's Avatar
Default Re: (teknoracing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teknoracing &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for all the input, im just really hoping someone will see this and post up a dyno sheet </TD></TR></TABLE>
Nobody is going to dyno their car with just a prc im. Instead of brooding over the issue, I'd recogmend modding around this until you are bottle-necked and do in fact need a free-er flowing im.
Old Jan 3, 2006 | 12:43 PM
MissRSX-S's Avatar
I'll try to see if I have an old one from 2 years ago. Like everyone is saying- if you have bigger cams and you run high rpms- ok cuz you'll notice it top-end. On the dyno sheet you'll see it in the upper part of the power band
Liu Kang
Jul 14, 2008 01:03 PM
leroyb
Mar 16, 2008 10:04 AM
jdm_vizionz
Aug 14, 2007 09:34 AM
GdmLaz
17
Jun 2, 2006 09:25 AM
B18cHatch06
Dec 9, 2004 06:37 PM
