Del Sol motor Swap?????
Old Mar 18, 2002 | 01:15 PM
AmericanImports's Avatar
Default Del Sol motor Swap?????
Need Info!!!
We might be doing an engine swap into a 1994 del sol S model. We will be removing the stock engine & AUTOMATIC trans and replacing it with what appears to be a 4th gen b16a out of a civic sir...with a cable operated clutch. How much more difficult is this swap over a hydraulic clutch, and what other parts will this require? ANY HELP IS APPRECIATED!!!
Thanks,
Tony
Old Mar 18, 2002 | 03:41 PM
MikeTheVike's Avatar
Default Re: Del Sol motor Swap????? (AmericanImports)
I did a b16 swap into my S, but I went from automatic to Hydraulic manual, so I don't know much, but I think you need a custom mount kit (HASPORT maybe?)
Old Mar 18, 2002 | 07:19 PM
topher's Avatar
New User
ummmmmmmm
its a b16a1 if it has a cable clutch
simple as tha
and if thats the case
u WILL need an HASPORT kit for it
Old Mar 19, 2002 | 08:38 AM
Default Re: Del Sol motor Swap????? (topher)
THANKS! I totally forgot about HASPORT. They should have that kit. I wasn't sure If it was a b16a1 or not. Thanks for the info.
Old Mar 19, 2002 | 11:52 AM
3.3.3's Avatar
j00 need the cable to hydro conversion kit y0. its a bitch to go from auto to manual. best of luck.
hontard
May 28, 2011 06:50 PM
boosting sol
Oct 14, 2009 08:26 AM
DTK
Jul 24, 2008 03:01 PM
93first1
Mar 6, 2006 10:53 PM
97_Prelude
Apr 21, 2001 08:59 AM
