My 93 Civic needs an engine and...
I just got a 93 Civic DX auto and it has a hole in the side of the block. I'm not looking for anything fast, I actually bought this car cause it's slow. So, what engine blocks can I use to replace mine? And what year cars did they come in? I know this stuff is listed some places but I dont' know what a b16a, b16b, etc are so it isn't really helpful.
I'm looking for a direct or close to direct bolt on for my car. Obviously nothing that is going to cost a lot in extra parts.
And what is the stock engine code? It's a 1.5L sohc?
anything starting with a 'B' isnt what you want. here check this out
EW4 1.4L & 1.5L SOHC PGM-Fi '84-'87 Civic 60-92hp
D15B 1.5L SOHC non-VTEC '88-'95 Civic's 62-102hp
D16A1 1.6 L DOHC 86-89 Integra 86/87 113hp 88/89 118hp
D16A6 1.6L SOHC 88-91 Civic Si/ CRX Si 108hp
ZC JDM equivalent of D16A1 130ps
D16Z6 1.6L SOHC VTEC 92-95 Civic EX/Si 125hp
D16Y5 1.6L SOHC VTEC-E 96-00 Civic HX 115hp
D16Y7 1.6L SOHC non-VTEC 96+ Civic CX/DX/LX 106hp
D16Y8 1.6L SOHC VTEC 96+ Civic EX 127hp
B16A 1.6L JDM DOHC VTEC 89-91 Civic Si-R I/CRX Si-R, Integra RSi/XSi 160ps
B16A2/3 1.6L USDM DOHC VTEC 93-97 DelSol VTEC/99-00 Civic Si 160hp
B16A 1.6L JDM DOHC VTEC 92-95 Civic Si-R II/ 92-97 CRX DelSol SiR 170ps
B16B 1.6L JDM DOHC VTEC 98+ Civic Type R 185ps
D17A2 1.7L SOHC VTEC-E 01 Civic EX 127hp
D17A1 1.7L SOHC non-VTEC '01+ Civic DX/LX 115hp
B17A1 1.7L USDM DOHC VTEC 92-93 Integra GS-R 160hp
B18A1 1.8L USDM DOHC non-VTEC 90-93 Integra RS/LS/GS 90-91: 130hp / 92-93: 140hp
B18B1 1.8L USDM DOHC non-VTEC 94-01 Integra RS/LS/GS 140hp
B18C 1.8L JDM DOHC VTEC 94+ Integra SiR-G 180ps
B18C1 1.8L USDM DOHC VTEC 94+ Integra GS-R 170hp
B18C5 1.8L USDM DOHC VTEC 97+ Integra Type R 195hp
B18C6/7 1.8L JDM DOHC VTEC 96+ Integra Type R 200ps
B20A5 2.0L DOHC non-VTEC 87-91 Prelude 2.0Si 135hp
B20B 2.0L DOHC non-VTEC 96-98 CR-V 126hp
B20Z 2.0L DOHC non-VTEC 99-01 CR-V 143hp
B21A1 2.1L DOHC non-VTEC 90-91 Prelude Si 145hp
K20A3 2.0L DOHC i-VTEC '02+ RSX
'02+ Civic Si 160hp
K20A2 2.0L DOHC i-VTEC 02+ RSX Type S
02+ Civic TypeR 200hp
K20A 2.0L JDM DOHC i-VTEC '02+ Integra Type R 220ps
F20A1 2.0L JDM DOHC non-VTEC 90-93 Accord Si 155hp
F20B 2.0L JDM DOHC VTEC 90-93 Accord Si-R 190ps
F20C1 2.0L DOHC VTEC '00+ S2000 250ps/240hp
F22A1 2.2L USDM non-VTEC 92-96 Prelude S 90-93 Accord LX/EX
130hp-135hp
F22B 2.2L USDM SOHC VTEC 94-97 Accord EX/97 2.2CL 145hp
F23A5 2.3L USDM SOHC 98+ Accord DX 135hp
F23A1 2.3L USDM SOHC VTEC 98+ Accord EX & LX/98-99 2.3CL
150hp
F23A4 2.3L USDM SOHC ULEV VTEC 98+ Accord EX & LX 148hp
H22A1 2.2L USDM DOHC VTEC 92-96 Prelude VTEC 190hp
H22A4 2.2L DOHC VTEC 97-01 Prelude VTEC/SH 97-98: 195hp 99-01: 200hp
H22A 2.2L JDM DOHC VTEC 92+ Prelude Type-S, 97+ Prelude SiRS Spec 220ps
H23A1 2.3L USDM DOHC non-VTEC Prelude Si 160hp
G25A1 2.5L USDM SOHC non-VTEC 96-98 2.5TL 176hp
J25A 2.5L JDM SOHC VTEC V6 JDM Honda Aspire/Sabre 200ps
C27?? 2.7L USDM SOHC non-VTEC V6 86-89 Legend 150-160hp
C27?? 2.7L USDM SOHC non-VTEC V6 95-97 Accord V6 170HP
C30A(?) 3.0L DOHC VTEC V6 91-96 NSX/NSX-T 270hp
J30A1 3.0L USDM SOHC VTEC V6 98-02 Accord V6/97-99 3.2CL 200hp
C32A6 3.2L USDM SOHC non-VTEC V6 91-95 Legend Sdn, 91-92 Legend Cpe 96-98 3.2TL 200hp
C32A5 3.2L USDM SOHC non-VTEC V6 94-95 Legend GS Sdn, 93-95 Legend Cpe 230hp
C32A? 3.2L DOHC VTEC- V6 97+ NSX/NSX-T 290hp
J32A1 3.2L USDM SOHC VTEC V6 98+ 3.2TL/3.2CL 225hp
J32A2 3.2L USDM SOHC VTEC V6 00+ 3.2CL Type-S, 01 3.2TL Type-S 260hp
C35A2 3.5L USDM SOHC non-VTEC V6 3.5RL 215-225hp
J35A1 3.5L USDM SOHC VTEC V6 98+ Odyessy 210hp
J35A3 3.5L USDM SOHC VTEC V6 Acura MDX 240hp
and what you have is 'D15B 1.5L SOHC non-VTEC '88-'95 Civic's 62-102hp'
why not look for another one since you want a straight swap plug n play no problems or adjusments or mods.
'02+ Civic Si 160hp
130hp-135hp
150hp
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96dxpower »</TD></TR><TR><TD CLASS="quote">what you have is 'D15B 1.5L SOHC non-VTEC '88-'95 Civic's 62-102hp'</TD></TR></TABLE>
He doesn't have all of the 1.5L D series engines, just one.
Just writing down "d15b" isn't anywhere close to helpful because the only d15b is a japan only engine that puts out a little over 130hp and has vtec.
To the thread starter, your engine is a d15b7 (sohc, non-vtec). You can find another one for dirt cheap (literally), or spend an extra $50-100 and get a d16z6 which came in the ex and si. The only thing with this one is that you'll need the corresponding ecu (or get yours chipped to serve the same purpose) and will need to run an extra wire for the vtec solenoid. Even with getting the z6 and the ecu it'll still only be a couple hundred dollars in good condition.
EDIT: You're engine code is stamped on the left side of the block, facing towards the front of the car and angles up a bit.
Modified by transpar_nt at 7:59 PM 12/27/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by transpar_nt »</TD></TR><TR><TD CLASS="quote">He doesn't have all of the 1.5L D series engines, just one.
There's also the d15b (only in japan) that puts out a little over 130hp...
</TD></TR></TABLE> what? i dont think i mentioned anything about him owning all the d series engines... i posted all these engine codes so he can have a btter understanding... he did say "I dont' know what a b16a, b16b, etc"
yes there is also the d15b that puts 130... similar to our d16z6...
There's also the d15b (only in japan) that puts out a little over 130hp...</TD></TR></TABLE> what? i dont think i mentioned anything about him owning all the d series engines... i posted all these engine codes so he can have a btter understanding... he did say "I dont' know what a b16a, b16b, etc"
I happen to have a D15B SOHC VTEC for sale in my garage. $500 with tranny, no ship.
I'm not trying to jack your thread, just offering a possible solution if you're ever up this way, stop out and pick it up
B
.B
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96dxpower »</TD></TR><TR><TD CLASS="quote">D15B 1.5L SOHC non-VTEC '88-'95 Civic's 62-102hp</TD></TR></TABLE>
I took this to mean one of two things:
1) D15B_ (doesn't make sense because you didn't even mention which engine you were speaking of)
2) D15B (which doesn't correspond with the "non-vtec" and "62-102hp" part)
I just found it odd that you posted so many engines that he specifically said he wasn't interested in (I'm looking for a direct or close to direct bolt on for my car.). And then the one part of your list that actually applied to what he was asking about gave unclear/wrong information. Sorry for the misunderstanding...
Awsome thanks for all the replies.
I can normally find core engines easier/cheaper than I can a good one so, would the head off my D15B7 bolt right to the block for a D16Z6? Having the extra cid would be nice cause I don't want the car to be a turd, just not very fast. Also how much hp does my stock engine make? Hopefully not 62hp.
I'd like to have at least 100hp.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Red 211 »</TD></TR><TR><TD CLASS="quote">Awsome thanks for all the replies.
I'd like to have at least 100hp.</TD></TR></TABLE>
I'm not sure if the dowels are spaced differently between the b7 head and the z6 block (I'm more of B series guy). You're stock engine is rated at 102hp at the flywheel.
I'd like to have at least 100hp.</TD></TR></TABLE>I'm not sure if the dowels are spaced differently between the b7 head and the z6 block (I'm more of B series guy). You're stock engine is rated at 102hp at the flywheel.
arc_55
Jun 30, 2006 12:36 PM
