another prob
Old Dec 27, 2005 | 03:47 PM
tallguy's Avatar
Default another prob
1988 crx
b16 OBD0
Ok iv had nothing but issues with my damn car for the past 6 months or so and now im getting mad like (the first person to throw some cash this way can have it) pissed. Ok the other day i was driving down the road and the car just died I started the car and was like Oh well and was on my way. Then the next day i was on my way to work and the car died again but would not turn over. So my question is what could cause this, there are no cel's nothing the car drives fine but just dies.
Old Dec 27, 2005 | 05:57 PM
tallguy's Avatar
anyone.... i know i just posted it but i have to be at work by 5am.
Old Dec 27, 2005 | 06:03 PM
C1CRX's Avatar
Traffic signal tech
Default Re: (tallguy)
sounds ignition related check your ignitor,coil,cap and rotor
Old Dec 27, 2005 | 06:28 PM
tallguy's Avatar
Default Re: (lvcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lvcrx &raquo;</TD></TR><TR><TD CLASS="quote">sounds ignition related check your ignitor,coil,cap and rotor</TD></TR></TABLE>
will the ignitor shut the car off if its already running?
Old Dec 27, 2005 | 06:41 PM
C1CRX's Avatar
Traffic signal tech
im not sure but a bad coil will
Old Dec 27, 2005 | 06:50 PM
1.6civicturbo's Avatar
id check the coil
tallguy's Avatar
Default Re: (lvcrx)
where is the coil on the dist? and is there any way to test it?
Modified by tallguy at 8:05 PM 12/27/2005
Old Dec 27, 2005 | 08:50 PM
ef2_civic's Avatar
this is a issue with obd0 stuff regardless it is vtec or non
the dizzy suck *** I had to replace two of them in the pass 3 years
yes it can cause the car to die but so can a main relay(under dash on driver side panel)
Old Dec 28, 2005 | 08:53 AM
tallguy's Avatar
Default Re: (ef2_civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef2_civic &raquo;</TD></TR><TR><TD CLASS="quote">this is a issue with obd0 stuff regardless it is vtec or non
yes it can cause the car to die but so can a main relay(under dash on driver side panel)</TD></TR></TABLE>
what do i look for in the main relay?
Old Dec 28, 2005 | 10:48 AM
classic69's Avatar
try a new relay see if it fixes it but there is a checking procedure with a multimeter...not sure where you get that though
Old Dec 28, 2005 | 11:31 AM
tallguy's Avatar
ok the car starts for a sec then shuts off. wtf could it be? I searched the info on the relay and its didnt match to my symptoms..
tallguy's Avatar
but thanks for the help so far and keep it coming.
Old Dec 28, 2005 | 11:39 AM
Black4thgenEF's Avatar
The main relay has been the cause of alot of strange problems. It might be worth it to change it.
Old Dec 28, 2005 | 11:54 AM
tallguy's Avatar
what ignitor/coil do i get at the parts store. do i get the one for a 90-91 integra.
Old Dec 28, 2005 | 02:28 PM
tallguy's Avatar
fixed the prob. it was the coil. thanks for everyones help.
Old Dec 28, 2005 | 02:46 PM
C1CRX's Avatar
Traffic signal tech
happy to help
torr
Apr 24, 2024 09:35 AM
Mr. Self Destruct
Jun 29, 2009 08:37 AM
themex77
11
May 9, 2007 04:54 PM
tour de france turbo
Aug 6, 2003 02:57 PM
allmtr
Jul 10, 2003 02:40 PM
