90 crx no start
Old Dec 27, 2005 | 02:21 PM
hroosevelt's Avatar
Default 90 crx no start
I am having trouble with my 90 crx, duel point injection. I'm not getting any fuel delivered. There is power to the fuel pump when the wires are disconnected, but when I connect the power wire it disappears. or gets grounded out, what is causing the power to disappear. I've checked the fuel injectors, they check ok. The main relay checks ok. and the fuel pump is good. Any ideas or answers would be greatly appreciated.
Old Dec 27, 2005 | 02:26 PM
I Have an STD's Avatar
wrenchin'
Default Re: 90 crx no start (hroosevelt)
you need a main relay. even if it checks ok, crank the car and smash the dash on the left hand side above the vent, if it starts, you've found the culprit
Brett
Old Dec 28, 2005 | 07:30 AM
hroosevelt's Avatar
Default Re: 90 crx no start (I Have an STD)
What good does hitting the dash do? Is there a short in the main relay?
Old Dec 28, 2005 | 03:57 PM
wrenchin'
just TRUST ME. it works. if the main relay is the problem, the car will start
Brett
Old Dec 28, 2005 | 09:38 PM
ktp1798's Avatar
Find the main relay and put the butt end of a screwdriver on it. Have someone crank the car and tap the other end of the screwdriver with a wrench or small hammer. Same as the above post, just a different way that always works for me.
Old Dec 28, 2005 | 09:58 PM
downest's Avatar
Default Re: (ktp1798)
Or just pull it out and look at it, when the solder goes you can see the cracks, just resolder it and you will be all set. Takes about 20 minutes, including removal and installation, most of that time is waiting for the iron to heat up.
Old Jan 8, 2006 | 01:20 PM
hroosevelt's Avatar
Hey, thanks for the info. I didn't hit the dash, but just smacked the relay and no problems. I was getting ready to sell this thing. Thanks again
Old Jan 8, 2006 | 01:42 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
http://www.marklamond.co.uk/ho...y.htm
http://honda.hybrids.jp/tech/p...shtml
brandonDAvid
Feb 12, 2011 11:40 AM
Hugsnkisses01369
Aug 18, 2006 02:46 PM
MooreBoost
10
Sep 8, 2004 07:43 PM
gcajnr21
Sep 8, 2002 11:21 AM
