NEED HELP! ZC questions and ITB setup.
I have just recently purchased a dohc ZC motor and had a few ?. What timing belt would I use to replace the stock one/ where could i get one. Would a d16z6, d16y8, ....sohc vtec head gasket fit a dohc motor, and if not where would I get a replacement. jdm ZC motors can be hard to find parts for which im sure you all know. Also Im thinking about getting a custom ITB setup for my stock ZC motor and was wondering what power gains i should expect, if any, or if that would just bog the motor bad at low rpms/ a sloppy idle?? thanks guys.
You should be able to use a timing belt from an older 2.0L Prelude P/N 14400-PK2-004 and if I'm not mistaken a head gasket from a D16A6
boosted_zc
Mar 21, 2003 03:54 PM
