how do i get the tps off?
Old Dec 27, 2005 | 11:34 AM
AJxr's Avatar
Default how do i get the tps off?
got my new z6 throttle body today and sure enough the tps was broken, my question is how do i get this sucker off?
Old Dec 27, 2005 | 11:43 AM
CRXSI_09's Avatar
Default Re: how do i get the tps off? (AJxr)
I took a dremmel drill and cut grooves that I could fit a flat head screw driver in and just screwed them out.
Old Dec 27, 2005 | 11:44 AM
wickedEFguy's Avatar
Default Re: how do i get the tps off? (CRXSI_09)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXSI_09 &raquo;</TD></TR><TR><TD CLASS="quote">I took a dremmel drill and cut grooves that I could fit a flat head screw driver in and just screwed them out.</TD></TR></TABLE>
then go to the store and get some bolts so you'll never have to use a dremel again.
correct me if I'm wrong people but I think it's a 8mm bolt?
Old Dec 27, 2005 | 11:55 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: how do i get the tps off? (wickedEFguy)
5mm x .8mm pitch is the size..
The length is about 15mm..
Old Dec 27, 2005 | 12:44 PM
EFbomb's Avatar
Dont forget to calibrate it when you get it back in the engine and hooked up to the harness.
5 volt refrence
Evasion
Aug 20, 2010 05:37 PM
cehcivic15
Aug 14, 2009 01:56 AM
jhota
Sep 2, 2006 10:05 AM
TURBODC4TEG
Aug 25, 2004 11:59 AM
htownteg
Jan 24, 2004 08:48 AM
