TURBO
Old Dec 26, 2005 | 11:35 PM
CRXsiproject's Avatar
Default TURBO
I have a crx with an ZC SOHC, and i was wondering if i wanted to add an turbo how much would it cost me.
Old Dec 27, 2005 | 12:19 AM
Redline130's Avatar
Default Re: TURBO (CRXsiproject)
It all depends on what size turbo you are going to use, plus whether or not you are going to use an intercooler, you'll need intercooler piping, a blow-off valve, possibly a wastegate, some sort of fuel and/or ignition management system(s), possibly larger fuel injectors, plus some other odds and ends. If you are on a tight budget, get your stuff from either ebay or check out the classifieds on this site, always good deals to be had. You just need to do your research.
Old Dec 27, 2005 | 06:29 AM
QuarterMileMaster's Avatar
What kind of hp you wanting? How much money are you wanting to spend? You gonna build the setup yourself?
Old Dec 27, 2005 | 06:52 AM
Smokinsax's Avatar
The Boot
http://www.homemadeturbo.com
Old Dec 27, 2005 | 08:13 AM
nblkid's Avatar
Default Re: (Smokinsax)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Smokinsax &raquo;</TD></TR><TR><TD CLASS="quote">http://www.homemadeturbo.com </TD></TR></TABLE>
Old Dec 27, 2005 | 09:03 AM
Markb16a's Avatar
homemadeturbo.come sucks would never go there.
Old Dec 27, 2005 | 09:52 AM
nblkid's Avatar
Default Re: (Markb16a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Markb16a &raquo;</TD></TR><TR><TD CLASS="quote">homemadeturbo.come sucks would never go there.</TD></TR></TABLE>
homemadeturbo owns you bitch
Old Dec 27, 2005 | 09:55 AM
AJxr's Avatar
i agree, thats where i got the inspiration to make my own setup.
Old Dec 27, 2005 | 10:43 AM
red cx's Avatar
this site was where I used to go years ago. It helped me out.
Old Dec 27, 2005 | 11:34 AM
highroller54's Avatar
Default Re: (nblkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nblkid &raquo;</TD></TR><TR><TD CLASS="quote">
homemadeturbo owns you bitch</TD></TR></TABLE>
haha i'm with this one, very good info for what you want
Old Dec 27, 2005 | 05:59 PM
Smokinsax's Avatar
The Boot
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Markb16a &raquo;</TD></TR><TR><TD CLASS="quote">homemadeturbo.come sucks would never go there.</TD></TR></TABLE>HAHAHHHAAHAHA....
Old Dec 27, 2005 | 08:39 PM
CRX EF 88's Avatar
dont listin to NBLkid. hes a little bitch.
Old Dec 27, 2005 | 08:40 PM
nblkid's Avatar
HMT is the ****, for those of you who dont think so,.... heres your m4d tyte jdm vtec solution....
Old Dec 27, 2005 | 10:53 PM
Mach69's Avatar
You could probably get everything for a under a grand.
Junkyard for turbo, wastegate, blowoff valve. 88-89 Hf manifold with adapter. Intercooler/Piping. Larger Injectors. Large Fuel Pump. EMS.
Thats all.
Old Dec 28, 2005 | 12:49 AM
julio_bOostamante's Avatar
I'm a Jackass
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nblkid &raquo;</TD></TR><TR><TD CLASS="quote">something stupid markcockmonger said</TD></TR></TABLE>yOU SIR ArE gRADE A dOUCHE Material. You need to do us all a favor and [/YOURSELF]
HMT OWNZ JoO
Old Dec 28, 2005 | 12:56 AM
I'm a Jackass
Default Re: (julio_bOostamante)
depending on what OBD electronics is on your car will determineif you run Turbo Edit Or Uberdata. This will be your engine management. along with this you will need some larger injectors like 390cc or 450cc from 1st gen or 2nd gen eclipses. from there pick a turbo that best suits your current engine. T3's are good choices depending on their AR's. any Saab Turbo will be good. Even Ford Thunderbird turbos. After you pick up your turbo go out and look into either an HF manifold or a Log style manifold. Both can be purchased fairly cheap. Again going to Homemadeturbo.com and looking in the classifieds will help. your gonna need charge pipes fabricated or ghetto rigged. with that said a downpipe needs to be made. Blow off vlave will be up to you as to what brand type style Etc. DSM BOV's are nice and so are Bosch. botha re cheap and effective.
If your going for a low budget set up your looking to spend about 1,000 to 1,500. If you do any of the work yourself it will obviously cost you less.
PM me if you need any parts made ( B or D series manifold and charge pipes and Down pipes.)
Good luck
Julio
Old Dec 28, 2005 | 07:19 AM
staticCRX's Avatar
http://www.turbod16.com/ &lt;-- has some good stuff if you are turboing a D series.
Old Dec 28, 2005 | 08:24 AM
Mr.Death's Avatar
3 grand should suffice.
Old Dec 28, 2005 | 08:52 AM
HiProfile's Avatar
Default Re: (Mr.Death)
I had a nightmare that I was forced to buy a Greddy kit last night. :shivers:
Figure $2k to do it decent on a d-series, everything said and done.
Old Dec 29, 2005 | 03:52 PM
ek_slut's Avatar
Default Re: (HiProfile)
homemadeturbo.com is as good as sex.......kinda
Scris21
36
May 24, 2007 09:57 AM
efin
Jul 6, 2006 12:27 PM
desiromeo812
May 6, 2005 10:18 PM
eh2..765
Mar 4, 2005 07:37 PM
tig488
Aug 10, 2004 05:59 AM
