Calling all Kenji P28 user's
Old Dec 26, 2005 | 10:25 PM
Shaka01's Avatar
Default Calling all Kenji P28 user's
I have a 97 ex with a b16a2 swap. I've had the motor in there for 3 yrs this Feb and just found out that the gsr ecu I'm running is not the right ecu I should be running. So I ask you if I buy a Kenji P28 with the wire harness will I be able to run it without a tune and if so how long, I have just a I/H
Thanks
Alex
Old Dec 26, 2005 | 11:23 PM
SOHCEK-Turbo's Avatar
Default Re: Calling all Kenji P28 user's (Shaka01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shaka01 &raquo;</TD></TR><TR><TD CLASS="quote">I have a 97 ex with a b16a2 swap. I've had the motor in there for 3 yrs this Feb and just found out that the gsr ecu I'm running is not the right ecu I should be running. So I ask you if I buy a Kenji P28 with the wire harness will I be able to run it without a tune and if so how long, I have just a I/H
Thanks
Alex</TD></TR></TABLE>
Kenji P28? Just ask for the a b16 basemap to be burned to the chip and your good to go.
Old Dec 27, 2005 | 01:27 AM
JDMlyfestyle's Avatar
Kenji is good Ive Delt with him alot and always had good results.
Old Dec 27, 2005 | 12:45 PM
Shaka01's Avatar
up for an answer
Old Dec 27, 2005 | 12:48 PM
Karizmah's Avatar
Yeah p28 stock as you may know is for a sohc. Like it was said, just have the dude burn the b16a2 base map on it that is if it's chipped.
Old Dec 27, 2005 | 02:16 PM
m00nr0ck Si's Avatar
Default Re: Calling all Kenji P28 user's (Karizmah)
When you order one he will email you and ask for your setup! I just got mine in the mail today, all I can say is, he does great work and he is very quick!!!
to Kenji
Old Dec 27, 2005 | 02:38 PM
Kool305's Avatar
Default Kenji P28
I suggest that you talk to him first and tell him what you want to do...he will give you a good deal/set up and you can take it from there...
I've dealt with him in the past NO COMPLAINTS awesome deals and great results... (check out my signature)
Old Dec 27, 2005 | 03:32 PM
kenji's Avatar
25 Year Member
Default Re: Kenji P28 (Kool305)
Send me an email. I will do my best to take care of you.
Thanks for the kind words guys. I really appreciate it and I really appreciate your business.
-kenji
trip-doh
Jun 27, 2011 03:59 PM
Revolution2zz
Aug 10, 2006 07:52 AM
SL_RICK83
Mar 5, 2006 07:46 PM
havalilsi
Oct 4, 2004 11:57 AM
CunninLynguist
Dec 16, 2002 09:33 AM
