clutch slave cylinder
my master clutch cylinder is starting to leak so it needs to be replaced, but how do i know if my clutch SLAVE cylinder needs to be replaced. i have 70,000miles on the car and a stage 2 clutch kit taking that into consideration.
Inspect the slave cylinder for any leakage, have you noticed any clutch pedal pressure problems, and feel the top of the clutch pedal for any fluid. I'm sure if you search around you probably could find other symptoms.
Ali
Ali
ive been looking around for sometime. clutch pedal is usually stiff as hell but i dont know if ive been getting used to the stiffness or its just the actual cylinder going bad. fluid is ok, there is some brake fluid drip stains though on my carpet in the car from the cylinder. and the slave cylinder, doesnt look like its leaking, just some normal engine bay dust and debree on it
SloCivicHMM
May 12, 2003 01:57 PM
