Extended wheel studs
Old Mar 18, 2002 | 10:21 AM
JRTurbo909's Avatar
From: Street Racing is ghey, I wanna live in Japanland
Default Extended wheel studs
Does anyone have them? How hard is the install? My friend needs to know because he said that they are a requirement for some sorts of racing?
Old Mar 19, 2002 | 05:28 AM
littlebluecrx's Avatar
Default Re: Extended wheel studs (JRTurbo909)
they are more tedious than hard, have to cut part of brake sheild to get to back of hub, then pull them thru slowly, at least if you use morroso studs like I did, if you use skunk or "z speed which I heard suck" then it should be like replacing stockers.you only need extended studs for dragracing as far as I know, if I am wrong correct me,good luck Jason
MugenEg
Dec 28, 2009 12:21 PM
ricehead
Nov 18, 2009 05:41 PM
2k.civic.si
Feb 22, 2005 07:49 PM
Tyson Ballou
15
Mar 1, 2002 06:31 AM
