Manual Trans fluid, what to buy and where?
Old Dec 26, 2005 | 08:06 PM
zx2gotboost's Avatar
Default Manual Trans fluid, what to buy and where?
1.5L sohc non vtec, Manual trans about 136,000 miles
Doing new axles and new trans fluid,
I bough 3 quarts of Vavoline 80-90 Gear oil, but then hesitated after I bought it.
So now im posting here for the Experts to tell me What fuild and where should I buy it, since I KNOW you all are going to tell me NOT to use it!
Lets start off, I got Autozone, Advanced and Napa Near me, who sells decent **** ?
Advanced only had Lucas and Vavoline and some cheap ****........
Old Dec 26, 2005 | 08:07 PM
blkhatch92's Avatar
get genuine honda tranymission fluid.
Old Dec 26, 2005 | 08:08 PM
littleredcivic's Avatar
DO NOT USE THAT OIL. your honda uses 5w30 SL grade engine oil. I only use HONDA MANUAL TRANSMISSION FLUID. But in a pickle, you can use any quality 5w30 engine oil. Mobil standard 5w30 is fine, buy it from Walmart for 1.82 a quart. You will need about 3 quarts to fill the transmission.
Old Dec 26, 2005 | 08:18 PM
Default Re: (littleredcivic)
Your saying I can use MOTOR oil? So I can use the same oil I use in my motor in my trans? Which is Vavoline 10w-30 non synthetic
Old Dec 26, 2005 | 08:19 PM
blkhatch92's Avatar
i was assumeing his car was manual . . .my bad, if its manual, use honda manual tranny fluid . . . or you can run motor oil . . .=[
Old Dec 26, 2005 | 08:22 PM
Default Re: (blkhatch92)
WOW, thats a NEW one to me, Motor oil in a trans? I was always told gear lube is btter for the differential..........
ok, off to walmart I go, So how bout some 10w-30 or 5w-30 Mobil 1 Motor oil or Vavoline ?
Old Dec 26, 2005 | 10:29 PM
don't bother with anything other than regular mobil 5w30 for 1.82 a quart. that is the closest to the factory honda fill.
Old Dec 27, 2005 | 12:21 AM
fmrprojects's Avatar
HONDA
Old Dec 27, 2005 | 12:34 AM
wwang924's Avatar
Default Re: (fmrprojects)
AMSOIL has manual tranny fluid, heard that was a top choice
Old Dec 27, 2005 | 12:46 AM
JDMlyfestyle's Avatar
Penzoil Synchromesh for me
Old Dec 27, 2005 | 01:10 AM
dohcVTECeg2's Avatar
Default Re: (JDMlyfestyle)
Honda Genuine MTF
Old Dec 27, 2005 | 03:34 AM
JimmyAtlantis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by littleredcivic &raquo;</TD></TR><TR><TD CLASS="quote">You will need about 3 quarts to fill the transmission.</TD></TR></TABLE>
I believe it's 1.8qts unless he's rebuilding the tranny, then it's somewhat more. Use either Honda MTF or GM Syncromesh FM.
Old Dec 27, 2005 | 05:44 AM
you may be right on the capacity, i suggested 3 just in case he found a way to dump out more than what usually comes out of the drain bolt.
Old Dec 27, 2005 | 06:35 AM
Well, Last time I used Penzoil, I think it may have F%^ked up my trans, It was also told that it was great for my ford, even though it says for GM and Chrystler use.
BTW, at VERY high rpms, I grind 3rd gear
Old Dec 27, 2005 | 06:41 AM
96dxpower's Avatar
Default Re: (dohcVTECeg2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcVTECeg2 &raquo;</TD></TR><TR><TD CLASS="quote">Honda Genuine MTF </TD></TR></TABLE>
go to the dealer and theyll help you out
Old Dec 27, 2005 | 06:46 AM
Default Re: (96dxpower)
ok ok, i may have to do that, just figured/assumed the dealer would charge me out the *** for th4e fluid, so Id rather buy some **** around here that is aight to use, like mobil one or penzoil.........
Old Dec 27, 2005 | 07:14 AM
the honda manual transmission fluid is an engine oil with an additive from what my friend at honda america told me. it is under 4 bux a quart at the dealer. if you are going to use something other than the original manual transmission fluid, buy the regular mobil. it is the closest to the honda factory fill, honda oil is made by mobil. if it was meant to be synthetic, the factory would have filled it with synthetic.
Old Dec 27, 2005 | 08:59 AM
Kool305's Avatar
GM SYNCHROMESH I vouch! that stuff is good ****
just hit up your local GM dealership and get some...
Old Dec 27, 2005 | 09:14 AM
Gearspeed-Performance's Avatar
Default Re: (Kool305)
Honda MTF Do not use any type of heavy GEAR OIL...for your trans.
Old Dec 27, 2005 | 09:19 AM
wow, dusputes, gm synchromesh &gt; Mobil
BTW, penzoil is sold at autozone
Old Dec 27, 2005 | 09:56 AM
THE LORD OF CHAOS's Avatar
Either honda MTF, Synchromesh, or 5w30. i will only use Honda or synchromesh in my honda. the 5w30 is only for a "temporary" thing though. the MTF have extra anti-wear additives to protect your tranny.
Old Dec 27, 2005 | 11:35 AM
johnecon2001's Avatar
Default Re: (fistandauntilus)
I just put AMSOIL in mine. I noticed a big difference. Seemed like the gears went in smoother and the whole car accelerated faster. It's a Synchromesh as well.
Could just be me getting loopy on fumes from exhaust.. but I swear it was better than the stock MTF.
https://www.amsoil.com/storefront/mtf.aspx
Old Dec 27, 2005 | 11:48 AM
Default Re: (johnecon2001)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnecon2001 &raquo;</TD></TR><TR><TD CLASS="quote">I just put AMSOIL in mine. I noticed a big difference. Seemed like the gears went in smoother and the whole car accelerated faster. It's a Synchromesh as well.
https://www.amsoil.com/storefront/mtf.aspx</TD></TR></TABLE>
Worth a shot?
Aight, Well I appriciate all of youyr comments, opinions,
I went to advanced. returned the Vavoline crap and went to honda and got the basic Honda trans fluid!
thank you! I hope im going to be happy!
O- and it cost me 25.00 after taxes. so a lil more than other stuff, but, if you say its good I got it!
Old Dec 27, 2005 | 10:23 PM
Default Re: (zx2gotboost)
Well, new axles are in, Honda fluiod in with a tiny bit of Lucas oil additive, got in my car started it up, pushed clutch in and moved shufter first to second to 3rd gears, WOW, what a difference NEW tranny oil makes, shifts better than it did! and thats at Idle.
But another problem..........................
When I pulled the lower control arm balljoint, the cotter pin was broke off in the castle nut (17mm) I loosened the castle nut anyway, now I CANNOT put the castel nut back on all the way!!! thankfully I got it on 2 or 3 threads, but thats all!
So im screwed once again.................
and I know nothing about that balljoint, I wonder if I can just replace the ball joint thing?
