Is my valve cover gasket blown? (pic)
Old Dec 26, 2005 | 05:30 PM
nk2k2's Avatar
Default Is my valve cover gasket blown? (pic)
if you look at the picture you can see like a line were it looks like oil has been accumulating and im not sure if thats an indication that the vc gasket is blown or not. The motor has about 133k on it and im not sure if it has been replaced or not.
Modified by 4g4d at 8:46 AM 12/27/2005
Old Dec 26, 2005 | 05:38 PM
explictness's Avatar
Default Re: Is my valve cover gasket blown? (4g4d)
my mom's car had the same thing, but she only needed a new seal for her valve cover or something.
but who knows.....
Old Dec 26, 2005 | 05:58 PM
McLovin's Avatar
replace it. its around 10-15 bucks at honda. also while you are at it replace the rubber grommets too. 25 bucks at most for the whole project.
Old Dec 26, 2005 | 06:14 PM
nk2k2's Avatar
Default Re: (Russianwonder32)
what do the rubber grommets look like?
Old Dec 26, 2005 | 06:23 PM
Got_soy's Avatar
Default Re: (4g4d)
you will see them when you take the valve cover off, they are under the bronze caps under the acorn bolts
Old Dec 26, 2005 | 06:27 PM
donaldmejr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4g4d &raquo;</TD></TR><TR><TD CLASS="quote">if you look at the picture you can see like a line were it looks like oil has been accumilationg(sp) and im not sure if thats an indication that the vc gasket is blown or not. The motor has about 133k on it and im not sure if it has been replaced or not.
I know this is off topic but what brand intake is that??
Old Dec 26, 2005 | 06:33 PM
nk2k2's Avatar
Default Re: Is my valve cover gasket blown? (donaldmejr)
believe it or not, its a ebay intake. All i did was sand blast it. Put two layers of high heat primer and 3-4 layers of wrinkle paint. I was going to do gloss black but ive never seen a wrinkled color intake so i went with it and its just looks awesome.
Old Dec 26, 2005 | 06:37 PM
donaldmejr's Avatar
how does it fit??? b/c I bought one on ebay and it was a P.O.S. but if its a great buy then could you send me a link to the seller (if you have it???)
Old Dec 26, 2005 | 06:42 PM
nk2k2's Avatar
in terms of fit, its really close. im not even going to lie. its honestly made for a mpfi intake and i made it fit just barely on my dpfi. In terms of company you can use and generic seller. Just make sure its a cai instead of ram air. I was going to do a DIY on how to do paint the intake but i didnt have time to do it. Sorry but i dont have the sellers info.
Old Dec 26, 2005 | 07:00 PM
nk2k2's Avatar
Default Re: (4g4d)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4g4d &raquo;</TD></TR><TR><TD CLASS="quote">what do the rubber grommets look like?</TD></TR></TABLE>
Old Dec 26, 2005 | 07:09 PM
DelSolDon's Avatar
Default Re: (4g4d)
here you go, just order off this site: http://www.hondaautomotivepart...COVER or go to the honda dealer. if you order from the site, just get:
1-#83191 (valve cover gasket)
4-#83192 (spark plug tube seals)
2-#83199 (small washers for under nuts)
2-#83200 (large washers for under nuts)
at the bare minimum, get the #83191
Old Dec 26, 2005 | 07:56 PM
d16vtecx's Avatar
Default Re: (DelSolDon)
put some Hondabond on the corners of the vc gasket just in case
Old Dec 26, 2005 | 08:33 PM
efb16girl's Avatar
check your cam seal also
Old Dec 30, 2005 | 05:21 PM
nk2k2's Avatar
Default Re: Is my valve cover gasket blown? (efb16girl)
Can i get these parts at any generic parts store or does it HAVE to be from honda?
Aodhan
Sep 28, 2007 10:15 AM
RGK500
Feb 15, 2007 08:23 PM
Aespooncivic
13
Feb 22, 2005 11:07 PM
the_0ne
22
Mar 16, 2004 02:20 PM
02 coupe
Sep 19, 2003 10:28 PM
