bad valve seal??
Old Dec 26, 2005 | 05:25 PM
pennies_hatchie's Avatar
Default bad valve seal??
okay, here's my 2nd attempt at this. here was the 1st https://honda-tech.com/zerothread?id=1411682
anyways here goes again.
1. 98 gsr motor
2. no vtec, burning a lot of oil
3. previous owner did a replaced a bad valve (said vtec worked before that)
4. talked to a few people, said that it is possible an oil pressure problem but some are saying that it could be a bad vavle seal since the previous owner did replace 1 bad valve
5. im thinking previous owner didnt install the valve correctly, he did say that he didnt touch anything else
6. would having a bad valve seal make vtec not work (vtec does work when you hook it up to a switch, but cuts in and out)
so please help out thank you
Old Dec 26, 2005 | 08:11 PM
blkhatch92's Avatar
i assume having a bad valve seal would effect your oil pressure, resulting in no vtec . . . .
Old Dec 27, 2005 | 04:00 PM
Default Re: (blkhatch92)
tttt
Old Dec 27, 2005 | 05:05 PM
2k.civic.si's Avatar
Default Re: (pennies_hatchie)
the valve stem seal will not keep vtec from working....
Old Dec 27, 2005 | 06:51 PM
blkhatch92's Avatar
headgasket?
Old Dec 27, 2005 | 07:25 PM
littleredcivic's Avatar
follow the vtec diagnostic flow chart and see what you come up with. run a compression and leak down test. you could also head to an emissions test site and have them run a pretest and see what levels you come up high on to determine engine condition as well.
Old Dec 28, 2005 | 10:23 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blkhatch92 &raquo;</TD></TR><TR><TD CLASS="quote">headgasket?</TD></TR></TABLE>
just replaced with a brand new one
and theres no emmisions test site in MN
HellaFab
Jun 28, 2011 07:37 AM
7mile
Jun 10, 2010 09:53 PM
00blkSi
10
Mar 30, 2009 10:15 PM
cioli
Sep 29, 2005 06:45 AM
