Need help removing shift knob
Old Dec 26, 2005 | 03:59 PM
jdmxtacy's Avatar
Default Need help removing shift ****
i dont know how to remove the shift ****. I was told to just twist it off but it wont move does anyone know heres a few pics.
Old Dec 26, 2005 | 04:06 PM
jdmxtacy's Avatar
I dont think there are any allen screws on the momo thing to unscrew
Old Dec 26, 2005 | 04:11 PM
2ndName's Avatar
If you pull down the shift boot, the shifter goes all the way up to the shift **** correct? Or is there a part that attaches onto the shifter other than the shift ****?
And if pull the shift boot down, do you see any type of screws holding it down?
Just asking because if you do not see anything bolting the **** down, then you just rotate the **** counter clockwise. So towards the left. if you are facing the front of the car.
Twist the bad boy really hard, must be pretty snug or something.
Old Dec 26, 2005 | 04:30 PM
jdmxtacy's Avatar
i do not see anything bolted to it and ive twisted it as hard as i could it just wont move.
Old Dec 26, 2005 | 04:32 PM
93_teg_CT's Avatar
Default Re: Need help removing shift **** (jdmxtacy)
The shift **** is two pieces, the thing that says momo is a cover for the screws, untwist that botom metal piece, inside, like that guy above said, there should be three allens, do that and you're set.
Old Dec 26, 2005 | 04:33 PM
2ndName's Avatar
Get a wrench. Tape the tips so it will not damage the bottom end of the ****. Twist the f*cker off.
Old Dec 26, 2005 | 04:49 PM
DCnotTHEshoes's Avatar
lol, hold the shifter part and twist off the silver thing that says momo and then the silver thing slides down and then u got screws, unscrew them and slide it offf
Old Dec 26, 2005 | 04:59 PM
jdmxtacy's Avatar
hey its harder than it sounds i got a vise grip on it and when i turn it the shift **** moves with it
Modified by jdmxtacy at 6:28 PM 12/26/2005
Old Dec 26, 2005 | 05:13 PM
Arsenal's Avatar
Default Re: (jdmxtacy)
Yes, turn the momo thing so that it goes down.
The there will be three allen screws holding the **** on.
Undo those and pull the **** off.
Old Dec 26, 2005 | 05:39 PM
TheSpoonSwan's Avatar
Default Re: (Arsenal)
take a electric cutting tools and cut it make you a ghetto short shifter
Old Dec 26, 2005 | 05:42 PM
jdmxtacy's Avatar
i would cut it but i got a trust shift **** and i need it threaded
Old Dec 26, 2005 | 06:44 PM
verbal_assasin's Avatar
every momo shift **** is is held in place with 3 allen screws.
to get to it, u have to uncrew the "momo" cap out. i forgot which way, but im guessing its clockwise.
once that is removed, everything should be common knowledge.
if you cant figure that part out, you shouldnt be driving.
Old Dec 26, 2005 | 06:58 PM
2ndName's Avatar
Maybe he is turning the momo part counter clockwise instead of clockwise.
Counterclockwise will make the momo part go up, which gives you nothing because the shift **** is in the way.
Old Dec 26, 2005 | 07:45 PM
Racermech's Avatar
Default Re: (2ndName)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmxtacy &raquo;</TD></TR><TR><TD CLASS="quote">i dont know how to remove the shift ****. I was told to just twist it off but it wont move does anyone know heres a few pics.
Ok you see the little black part that says MOMO, it is right under the leather ****, but above the shift boot. That piece unscrews from the know. If you are looking at it just like this picture you would grab the little black part and turn it to the LEFT, this will unscrew the balck part with momo on it. This will reveal the three little set screw that actually hold the **** to the shifter. I have the same **** and this is how you take it out. You do not need vice grps, pliers or anything else, just a small allen key to loosen the 3 little screws.
Old Dec 26, 2005 | 07:48 PM
jdmxtacy's Avatar
Ok i got it thanks for your help everyone i really appreciate it.
tnewhallSi
Mar 31, 2006 11:44 PM
Shinbo
Oct 8, 2004 01:27 PM
pre1udekid
Jul 12, 2004 03:49 PM
andrewasf77
Nov 10, 2002 11:50 AM
joemama
May 24, 2001 05:01 PM
