Can I install sway bars on my 95 CX? How?
Old Mar 18, 2002 | 09:31 AM
vntperformance's Avatar
Default Can I install sway bars on my 95 CX? How?
HELP!
what is required?
please help.
vnt
Old Mar 18, 2002 | 09:46 AM
AmauryR's Avatar
Default Re: Can I install sway bars on my 95 CX? How? (vntperformance)
yeah, you might need to drill some holes if ur gonna run ur stock lca's (lower control arms). You can try using suspension tech's kit (they have 1 for the f/r).
Also an option is running ex/si front lca's, gsR rear lca's and run '94 'teg non-vtec front bar, and the gsR rear bar (as well as the respective links). Dunno for sure, but sounds pretty right, anyone elsE?
Old Mar 18, 2002 | 09:59 AM
stkd16z6's Avatar
Default Re: Can I install sway bars on my 95 CX? How? (SKiLLz-R)
yep, gotta have the EX/si Front LCA and 3g integra rear LCA. For a cheap setup just use the gs-r rear sway and ex/si front bar. the integra rear lca as well the DOHC vtec del sol rear lcas are a good upgrade, since you need the hole for the endlinks for almost any swaybar except the suspension techniques bars.
Old Mar 19, 2002 | 03:11 AM
Default Re: Can I install sway bars on my 95 CX? How? (stkd16z6)
Thanks. Guys...anyone else to clarify?
Vnt
Old Mar 19, 2002 | 04:01 AM
sohc_boy's Avatar
u could also go aftermarket like suspension techniques or somone similar. they make kits as a direct bolt on for your car, no swapping parts plus its got more clearance than running the factory stuff.
griffinjr123
Suspension & Brakes
Nov 16, 2009 02:53 PM
coupej1
Suspension & Brakes
Oct 13, 2008 06:26 AM
dpetro1
13
Jan 14, 2005 06:09 PM
SpydiR
Nov 17, 2004 04:14 PM
95integragsr1984
May 25, 2003 09:26 PM
