Can I install sway bars on my 95 CX? How?
Re: Can I install sway bars on my 95 CX? How? (vntperformance)
yeah, you might need to drill some holes if ur gonna run ur stock lca's (lower control arms). You can try using suspension tech's kit (they have 1 for the f/r).
Also an option is running ex/si front lca's, gsR rear lca's and run '94 'teg non-vtec front bar, and the gsR rear bar (as well as the respective links). Dunno for sure, but sounds pretty right, anyone elsE?
Re: Can I install sway bars on my 95 CX? How? (SKiLLz-R)
yep, gotta have the EX/si Front LCA and 3g integra rear LCA. For a cheap setup just use the gs-r rear sway and ex/si front bar. the integra rear lca as well the DOHC vtec del sol rear lcas are a good upgrade, since you need the hole for the endlinks for almost any swaybar except the suspension techniques bars.
u could also go aftermarket like suspension techniques or somone similar. they make kits as a direct bolt on for your car, no swapping parts plus its got more clearance than running the factory stuff.
griffinjr123
Suspension & Brakes
11-16-2009 02:53 PM
dpetro1
13
01-14-2005 06:09 PM
