Pic Request: Si rear sway bar endlinks on car
Old Dec 26, 2005 | 02:08 PM
Nsane1's Avatar
From: West Bakalakadaka St., Durka Durka Mohammed Gihad, WMDs
Default Pic Request: Si rear sway bar endlinks on car
My problem is that I bought a USDM ITR rear sway bar and the endlinks that we're on it were bent all to hell. So, I wanna make sure the bar's not bent before I go putting it on. I bought a Beeks subframe reinforcement kit in which you have to drill more holes in the subframe and would rather not do that right now if the sway bar is FUBAR. I need a pic of Si endlinks for the rear sway bar on the car so I can't figure out which way these go on. Plz, if you have a pic then post. I wanna just hold the bar up to it w/ the endlinks on it to see if it'll work before I go through all the work of getting it bolted on. Thanks in advance.
Old Dec 26, 2005 | 05:16 PM
Nsane1's Avatar
Default Re: Pic Request: Si rear sway bar endlinks on car (Nsane1)
come on, doesn't anybody have any pics of endlinks on the car?
Old Dec 26, 2005 | 05:23 PM
pdiggitydogg's Avatar
the hell do you have to drill holes for???
if it wasnt less than 30 degrees Id go snap a couple for you
Old Dec 26, 2005 | 05:39 PM
Nsane1's Avatar
Default Re: (pdiggitydogg)
Have to drill holes for the subframe reinforcement. If you could just point me to a picture on a website w/ a rear sway bar connected it would help.
Old Dec 26, 2005 | 05:44 PM
there are already holes on the subframe for D brackets...I dont see where you would need to drill anything at all
http://beaksproducts.com/EK_Quick_Swap.htm#
theres an image of the endlinks there - one end just goes through the bar, the other end goes through the lca, thats it
Old Dec 27, 2005 | 11:38 AM
Nsane1's Avatar
The reinforcement I bought from Beaks kinda expands the distance between the two holes. The top factory hole you use but you have to drill a hole further down from the bottom factory hole in order to use the reinforcement. As for the endlinks I have them here in my hand along w/ the sway bar. Since I guess you have a sway bar too then I'll just try to explain it to ya. do the endlinks connect to the sway bar on the inside or the outside of the holes? Do the endlinks connect to the LCA's from the front side of the car or the rear?
Old Dec 27, 2005 | 01:54 PM
bebfsu1's Avatar
Hope this helps, bar is no longer on the car so I can't take any more pics...
Old Dec 27, 2005 | 05:10 PM
Nsane1's Avatar
Default Re: Pic Request: Si rear sway bar endlinks on car (bebfsu1)
kewl, thanks a bunch
elmalouno
Feb 24, 2004 04:02 PM
patman18
Jan 25, 2004 02:28 PM
hondacivic4g
Dec 19, 2003 04:21 PM
Casual Gcode1
Feb 10, 2003 10:12 AM
