What the easiest way to clean inside of lense w/o taking apart?????
i need to know what would be the easiest way to clean dust from the inside of my headlights 98+ without taking them apart. i tried a blow gun but it wont take the dust off. i know this may sound stupid but someone told me to take a lil bit of water drip it in side swish it around drain it out then dry it wil a blow gun will that work or what??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by verbal_assasin »</TD></TR><TR><TD CLASS="quote">that should work, but use purified water so it wont leave any hard water stain.
i used a chopstick, folded papertowells and rubberband.</TD></TR></TABLE>
why a rubber band?
why a rubber band?
basically trying to get in front the of the projector galss into the main housing
cause the only thing i can get in that far was a big zip tie. thats why i said use some water swoosh some around drain it out then just use a blow gun to dry it all out
When I worked on flood cars and the lights got water in them I used a mixture of rubbing alcohol (so it would dry fast) and purified water (so it would not leave any hard water deposits). I think I did a 70/30 or 60/40 of rubbing alcohol/water. That should work to get the dust out of the headlights also.
BolivianFuego
Oct 8, 2004 02:40 PM
