Parts list for B16 swap into 95 coupe si.
Old Dec 26, 2005 | 10:53 AM
HamiltonRex's Avatar
Default Parts list for B16 swap into 95 coupe si.
Hi, posting this for a friend.
We are going to be doing a 99-00 Si swap (b16) into his coupe soon. We would like to know what parts we need. i have done some searching for him, but i just wanna make sure its all right before i tell him to order parts.
Mounts - Combination of his stock mounts, and the mounts that come with the motor
Shift linkage - 94-01 Integra Shift Linkage
Axles/Intermediate Shaft - 94-01 Integra (if 90-93 shaft used, must match seal)
These are the main things we are concerned about
Now.. Can we use the 99-00 Si mounts/linkage/axles? Since they will be comming with the swap, and we cant afford much downtime. Are they the same as the 94-01 Integra?
Thanks.. Any corrections please let me know.
Old Dec 26, 2005 | 04:04 PM
EK-SI's Avatar
Default Re: Parts list for B16 swap into 95 coupe si. (HamiltonRex)
im not 100% sure but im pretty damn sure that you can use all the stock si **** and it should work
Old Dec 26, 2005 | 04:16 PM
Innes's Avatar
Default Re: Parts list for B16 swap into 95 coupe si. (EK-SI)
all the 99-00 civic si axle assemble will bolt right into the '95 model year car
not all of the 99-00 civic mounts will work, see if you can locate a complete 94-01 integra mount kit as they will bolt onto the b16 engine and bolt directly into the '95 car
any 94-01 teg or 99-00 civic si shift linkage will work for you
Old Dec 26, 2005 | 04:17 PM
T.J.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK-SI &raquo;</TD></TR><TR><TD CLASS="quote">im not 100% sure but im pretty damn sure that you can use all the stock si **** and it should work</TD></TR></TABLE>
yes you can use all the Si parts except the mounts . To tell what esle you need not sure becuase we dont know what else you already have.
Old Dec 26, 2005 | 04:38 PM
Default Re: Parts list for B16 swap into 95 coupe si. (T.J.)
Thanks everyone!
94-01 Integra Mounts
94-01 Integra or Civic Si shift linkage
94-01 or 99-00 Si Axles
Old Dec 26, 2005 | 04:42 PM
spuddo01's Avatar
you need 99-00 back mount bracket, 94 and up upper and front tranny mount, 94 and up AC bracket, and if it is a JDM b16 you cant use the 94 and up integra drivers side mount because it has three holes un less u get that bracket that bolts up to the block from a 94 and up LS; so i would use the JDM b16 mount for that and 94 and up integra back mount; or you can use all of the mounts from the 94 and up Del Sol VTEC with the b16 in it which are hard to find unless you order from honda but they will cost a lot; or stop being cheap like i was and just get hasport or some other brand that might be cheaper than hasport. Good Luck and i hope this info was useful.
PS you can use your stock driver side mount and back mount but the driver side will give in like the first week because you will drive the car like a maniac because you just put your new motor in it trust me take it from me.
Old Dec 26, 2005 | 04:44 PM
spuddo01's Avatar
Default Re: Parts list for B16 swap into 95 coupe si. (spuddo01)
you can also use 90-93 and 94 and up integra axles because i have a 93 coupe with a JDM b16 2nd Gen and i use the 90-93 axles. auto zone i gotta have that lifetime warrantee i go thru them like crazy so i will be getting performance axles soon.
Old Dec 26, 2005 | 04:52 PM
Thanks, i think i will get him to go with a lower budget set of aftermarket mounts
Old Dec 26, 2005 | 05:08 PM
life sux die's Avatar
RIP 1032
just get everything from a '94 Del Sol Vtec.
Old Dec 27, 2005 | 08:44 AM
spuddo01's Avatar
Default Re: Parts list for B16 swap into 95 coupe si. (life sux die)
i would say the same thing but its really hard to find unless you order it from the dealer but they will charge you an arm and a leg.
Old Dec 27, 2005 | 09:28 AM
Yes. Seems like he will go with some lower budget aftermarket mounts, and use the 99-00 Si shift linkages, and axles/shaft that come with the swap.
Thanks
YoSalinas
Dec 26, 2018 12:37 AM
knappy03
Jul 28, 2011 12:49 PM
radeonboy
Apr 8, 2009 04:57 PM
808Army
Jun 17, 2008 11:24 PM
its WANG yoO
Jul 9, 2003 12:27 PM
