2001 Civic EX EMII Suspension/Brake Swap ?
Old Dec 26, 2005 | 07:37 AM
toyomatt84's Avatar
Sanji
Default 2001 Civic EX EMII Suspension/Brake Swap ?
I was interested in a 5 lug swap for my EMII and was curious of the following:
Is there a kit out there yet for it?
Is there a good place to find RSX Type-S suspension/brake components out there?
Besides the Axles, CA's, Brake Components is there anything else needed? (like a Brake Booster...)
Is there a decent write-up with photos out there on how-to do it?
I know some people just say stick with four lug and get the rear discs off of another Civic, but I'll be needing the RSX components for a later engine swap and other such things.
Old Dec 27, 2005 | 09:05 AM
HapaHaole's Avatar
Default Re: 2001 Civic EX EMII Suspension/Brake Swap ? (toyomatt84)
get a 5 lug type S suspension.
Do not try to bother with Type R suspension on your civic unless you plan to roll the crap out of your fenders and repaint them to fit aftermarket wheels on the Type R suspension. You will need to find some weird wheels with 50+ offset to fit inside your fenders if you have the Type R suspension vs a type S suspension that is a bit narrower.
Old Dec 27, 2005 | 09:33 AM
Boilermaker1's Avatar
Swap the hubs with the motor. D-axles don't match K-hubs.
Old Dec 27, 2005 | 04:28 PM
toyomatt84's Avatar
Sanji
Awesome help guys, thanks a TON!
@HapaHaole: Are the Type-R CA's that much wider? Because, that's quite interesting information. What makes them different? (If you know)
@Boilermaker1: Just curious, Boilermaker1, but do the K-axles work with a D-engine? Or are the splines different on both ends?
Old Dec 27, 2005 | 06:53 PM
Default Re: (toyomatt84)
The answer to the first one is the Brembo brakes
the answer to the second one is you cannot use K axles with the D anything, visa versa.
The D is on the opposite side of the engine bay and the spline pattern is different. its a completely incompatible combination.
Custom axles are one option, people have hinted at pulling the RSX outer axle off and mating it to the rest of the D axle. I know nothing about this working.
Old Dec 28, 2005 | 02:14 PM
toyomatt84's Avatar
Sanji
Awesome. That totally puts things into perspective. Now, if it were you, and you weren't planning on swapping the D17 anytime soon. Would you recommend just sticking with a Rear Disc swap from another Civic, or is the 5-bolt a really good swap to have?
Old Dec 28, 2005 | 03:15 PM
It affords you larger brakes the RSX-S has. But the car doesn't weigh all that much, and 130 HP isn't much to contain. Even the disc swap is unnecessary.
I redid my brakes to counter overheating on the track (I now have DC2R 11.1" Fronts and EP3 rears, but for general driving, there's no point in anymore than new fluid, pads and a decient set of rotors.
Honestly I don't think its worth it just to get 5 lugs, there's a bajillion 4 lug wheels to pick from.
Old Dec 28, 2005 | 03:42 PM
toyomatt84's Avatar
Sanji
It wasn't the fact that it was 5-lugs that interested me. It was more on the lines of the fact that the brakes and suspension components were more tailored towards performance, than everyday driving.
Old Dec 31, 2005 | 12:51 AM
toyomatt84's Avatar
Sanji
I found your post on 7thgen, Boilermaker1. Is there any chance you could email me the corresponding pics to the Rear EP3 disc swap?
Old Jan 7, 2006 | 03:17 PM
Redline96LX's Avatar
* B A N N E D *
post the pics of the swap on here, I wanna see too.
Also, Ive seen outer K axle ends on B-series shafts, and I know that the B and D outers take the same stuff (99 Civic EX and Si, ones a D, ones a B.) But I cannot give ya 100% conformation that this will work, cause if the RSX suspension's centerline isnt the same as your civic, you'll need to have the axles cut, so go with custom axles anyway. Why do you want 5 lugs? Theres ways to get the same sized brakes without swappin the whole suspension.
Old Jan 7, 2006 | 07:59 PM
Becuase full 5 lug swaps have been seen going for $500. You can get about 1/2 a wilwood kit for that, which does little good.
Anyways, here's EP rears
And DC2R/Prelude 11.1" Fronts (which are still smaller than Type S brakes)
Old Jan 8, 2006 | 09:27 PM
toyomatt84's Avatar
Sanji
Absolutely gorgeous ride, Boilermaker.
VTecCivic1505
Honda Civic (2001 - 2005)
Nov 27, 2006 06:07 AM
Shocka1998LX
Aug 18, 2004 06:19 AM
SpikeLe
Jul 24, 2004 12:17 PM
