How to tell what spring rates...GC's
http://www.norcalcrx.org/tyson/coilover.html
How do I tell what my spring rates are?
Ground Control sells Eibach Race Springs (ERS) which are labelled by 3 different values in the following convention: length . diameter . spring rate. However, ERS will come labelled in either Metric (mm.mm.N/m) or English (inchx100.inchx100.lbs/inch) units. 180.64.61 is the same thing as 700.250.350. The conversion from Metric to English is (/.254, /.254, x5.7) "/" means "divide by", "x" means "multiply by".
Ok thats makes more since.
Heres what mine read:
Front:180.64.44
Rear:200.64.58
Front:708/251/250
Rear:787/251/330
So thats a 7 inch spring, 2 1/2 width spring, 250lb. spring rate in the front
7.8 inch spring, 1 1/2 width spring,, 330lb. spring rate in the rear.
Or am I off?
Front:180.64.44
Rear:200.64.58
Front:708/251/250
Rear:787/251/330
Or am I off?
Understeer
71
Dec 19, 2007 08:57 AM
pjr710
Suspension & Brakes
19
Apr 19, 2007 02:44 PM
