B-Series Swapped CRX, will ITB's with air box fit?
Old Dec 26, 2005 | 04:51 AM
krystianitr's Avatar
Default B-Series Swapped CRX, will ITB's with air box fit?
Hi B18-Series Swapped CRX, will ITB's with air box fit?
is there enough space for ITB with air box TWN in the CRX??
Old Dec 26, 2005 | 05:36 AM
zman's Avatar
Default Re: B-Series Swapped CRX, will ITB's with air box fit? (krystianitr)
think about what you are asking.
I would put on your flame retardant suit if i were you.
How is it possible to have an air box with individual throttle bodies? Unless you custom rig some sort of air box with 4 outlets to go to each individual throttle body.
But that would kind of defeat the purpose of ITB's.
Old Dec 26, 2005 | 07:10 AM
89crxhf's Avatar
i think he is asking if the air box made for itb will fit in the crx.
heres a link to it
http://www.twminduction.com/airbox.htm
as far as the question i dont know
Old Dec 26, 2005 | 09:53 AM
Default Re: B-Series Swapped CRX, will ITB's with air box fit? (89crxhf)
It is only itb in the crx, what do you thing is there enough space to put air box TWN?
Modified by krystianitr at 11:12 AM 12/26/2005
Old Dec 26, 2005 | 10:24 AM
dinko's Avatar
if you put a box over the ITB would it still be considered ITB? or a custom intake manifold? i mean what kind of gains do you think you're going to get with the TWM air box? if any...
i would leave it alone.
any more info on that setup?. it looks good...
Old Dec 26, 2005 | 10:55 AM
Default Re: B-Series Swapped CRX, will ITB's with air box fit? (dinko)
I want put air box TWN and intake without filters to lights,I show you a picture
Old Dec 26, 2005 | 11:06 AM
dinko's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krystianitr &raquo;</TD></TR><TR><TD CLASS="quote">
okay i understand what you're asking now. in the picture above, it looks like you have very limited space to work with. i think you're going to have to measure 4.75 inches from your fuel rail and that way you can find out if it will fit. otherwise you can buy it, and try to fit it. nothing fits perfectly. you might have to do a little customizing
Old Dec 26, 2005 | 01:04 PM
Disco Monkey's Avatar
a little off topic, but who makes that headlight scoop for crx's? since it has a jdmcars.com sticker on it i looked their site, but i did not see one.
Old Dec 26, 2005 | 01:22 PM
TrnsferErr's Avatar
u should just put filters over each throttle body :-D
Old Dec 26, 2005 | 01:40 PM
Default Re: (TrnsferErr)
drag car when have a custom intake to headlights to ITB they have filter for itb or wherever???
Old Dec 26, 2005 | 03:53 PM
rickncar's Avatar
it should fit and the air box will help funnel the air into the ITBs
huckduck
May 30, 2008 03:10 PM
whitepandaeg6
Sep 17, 2007 10:20 PM
sikefcrx89
Aug 24, 2007 07:50 AM
coot_er
26
Sep 15, 2004 07:53 PM
thefungus
Jul 22, 2001 07:41 PM
