92 lude h22 swap.
Old Dec 26, 2005 | 01:04 AM
1992hludesi's Avatar
Default 92 lude h22 swap.
ok so i wanna put a h22a1 in my 92 si, but i want to have the motor built first what what do you guys suggest as the best as far as, cams, valves, pulleys, pistons, rods, rings, axels, and lsd?
thanks
Old Dec 26, 2005 | 09:06 AM
Rosko's Avatar
Default Re: 92 lude h22 swap. (1992hludesi)
How fast do you want to go and what is your budget?
Old Dec 27, 2005 | 04:24 AM
Default Re: 92 lude h22 swap. (Rosko)
i have about 5k to put in to everything invoving the engine. and thats including the engine and tranny so for mods i have about 2-3k and my dream is 300HP after turbo and 230-250? before turbo... the engine im getting is $1950.00 for engine tranny and ecu... and its all lsd and stuff like that.... what can i do?
Old Dec 27, 2005 | 05:50 AM
shutta's Avatar
well for fully build turbo you are probably going to need a bit more i'd say. at the least you'll need pistons, turbo manifold, head work, turbo, intercooler and turbo misc., which isn't cheap and if you want to upgrade other stuff it only goes higher. Price out everything you want and just buy what you can work with for the time being..
Old Dec 27, 2005 | 04:40 PM
Default Re: (shutta)
ok let me re phrase what i ment... i have about 2-3k to spend on engine mods NOT includeing the turbo. i will have more money for the turbo at a later date. so 2-3k just for mods
skillzhb
Jan 16, 2009 08:06 AM
plikit
Jan 13, 2006 06:40 PM
mahatma
May 19, 2005 08:28 AM
idragbodys10
Jul 1, 2004 06:16 AM
1JDMDOMINICAN
Dec 14, 2003 04:08 AM
