b16a2 block with gsr head
Old Dec 25, 2005 | 07:37 PM
Ruben19's Avatar
Default b16a2 block with gsr head
im trying to buy new pistons for my b16a2 block
high compression between 11-to12.5
should i use the si timing belt or gsr belt.
and how high on octane gas can i go
you think 92 will be ok or something higher
Old Dec 25, 2005 | 07:39 PM
JDM SLEEP3R's Avatar
Default Re: b16a2 block with gsr head (Ruben19)
i think a GSR belt might be to big.
Old Dec 26, 2005 | 06:29 AM
RaceCarRyne's Avatar
Default Re: b16a2 block with gsr head (JDM SLEEP3R)
the b16 has a shorter deck height than the gsr so u will need the b16 timing belt.
Old Dec 26, 2005 | 11:13 AM
jdmjeff's Avatar
if im not mistaken it depents on what waterpump your running... w/a b16 water pump youll prob need a b16 timing belt... but thats just me!!! anyone else?
jdmjeff's Avatar
Default Re: b16a2 block with gsr head (jdmjeff)
oh and get some 310 injectors and get it tuned and youll be fine on 92 pump gas
Old Dec 26, 2005 | 11:17 AM
Surubasi00's Avatar
uh...
why put the GSR head on?
you will use the b16 belt oil pump doesnt matter, that's only with LS/VTEC
12.XX compression you will need to have **** hot tuning and good 91-93 octane gas, depending on where you live.
Think about this before you go buying pistons, you need to get them installed, you will need cams, cam gears, engine management, injectors, and of course exhaust and intake to take full advantage of such high compression
Dave
Old Dec 26, 2005 | 11:23 AM
jdmjeff's Avatar
Default Re: b16a2 block with gsr head (Surubasi00)
go mild w/ usdm itr pistions and settle w/ some ctr cams and perhaps a type R valve train w/ some injectors! youll be happy w/ the power gain and i will be depenable
hatchet_honda
Apr 11, 2009 11:16 AM
ricin4ever
Jun 20, 2008 09:31 PM
ricanem1
Jan 23, 2007 04:00 PM
del slw
Feb 1, 2006 04:02 AM
