Cyl No. 2 misfiring, speedometer and tramsmission speed sensor not working.
I have a situation I am tryig to help out a friend with. Cyl No. 2 misfiring(ECU code), speedometer and tramsmission speed sensor not working. I am trying to figure out what is all causing this? Any information would be helpful in directing me where to look or what might be the problem
well i would first check fuses for the spedo that was the case for my friend otherwise the vss for that. The misfiring could be many things but i would start off with a cap and rotar since they are cheapest then plugs then wires then 02 sensors
misfiring would not really be linked to it, the tach and spedo would be linked together my friends went nuts at the same time
madnad
Sep 18, 2018 06:49 AM
