oil pressure sensor
well i have found my leak to be coming from my oil pressure sensor!!! my valve cover gasket i am goin to replace as well. as well as my oil pan it has a substantial amout seepin thru!!! question is how hard is it to replace the pressure sensor?? or should i just take it to this performance shop i go to?
the oil is leaking onto my flex pipe under my car!!! could the leakage from the rear of the oil pan be causing this? cuz thats where the majority is seeping thru, or is it just the pressure sensor just drippin down!!!
any help will be much appreciated!!! thanx
whats the thread sealer!! **** cuz this getting old smelling burnt oil on my flex pip from where it has leaked!! one more thing is it true as u get on the gas is the pressure mostly likely making the sensor or the oil pan spew onto the exhaust??
