89 crx dx obd1 converstion
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmef9si »</TD></TR><TR><TD CLASS="quote">if i use 88-91 si dash harness then i would be able to use the engine harness which is already mpfi</TD></TR></TABLE>
No,it doesn't work like that..You would to swap in the entire Car harness..I mean everything..The easiest thing to do is use the stock dx harness and convert to mpfi..You only have to add a couple of wires and switch some around..Check out fourthgenhatch.com for a mpfi write-up..
im not worried about whats easiest.Why would i have to change out the whole wiring when the only difference in the si and dx is the dash harness and engine harness?
91EF_Si
13
Jul 3, 2007 04:27 PM
nitroracer
Sep 9, 2006 07:50 PM
0ptimus prime
Aug 20, 2004 09:14 AM
0ptimus prime
Aug 19, 2004 02:59 PM
