ENGINE OPTIONS?
Old Dec 25, 2005 | 11:12 AM
srt41320's Avatar
Default ENGINE OPTIONS?
JUST PICKED UP A 90 CRX HF I THINK - GOT A 1.5 NON-VTEC - TIRED OF SWAPPING SO I THINK I MIGHT TRY SOMETHING DIFFERANT FOR ONCE - WHAT ARE SOME THINGS I CAN DO WITH THIS MOTOR? OR SWAP IN A D16? OR BOOST OPTIONS? THANKS A LOT YAL!
Old Dec 25, 2005 | 12:42 PM
classic69's Avatar
Default Re: ENGINE OPTIONS? (srt41320)
simplest/cheapest swap would be zc or si motor.
Old Dec 25, 2005 | 12:45 PM
SiR Inspired ED7's Avatar
just get a Type AAAAAARRRRRR
get a single cam (a6) pretty strong lil drop in motors
ps: never use caps lock in honda-tech
Old Dec 26, 2005 | 03:39 PM
srt41320's Avatar
thanks a lot guys - is there a lot a wiring or ecu issues i need to work with if i swap a si or any single cam w/ vtec?
Old Dec 26, 2005 | 06:10 PM
EF86's Avatar
u have to get the ecu,harness, obd1 conversion.vtec tranny sensor of an eg with vtec.thats all i know.i have a 90 hb
Old Dec 27, 2005 | 06:15 PM
srt41320's Avatar
better yet - what would be a good autocross motor setup - i would like to keep it fairly simple and cheap since this is a side project...thanks
Old Dec 27, 2005 | 08:01 PM
Cuda70's Avatar
Default Re: (srt41320)
You could go with a D16ZC DOHC. They will pop right in, no wiring or changes needed. They give about the same HP/TQ as a D16Z6 SOHC Vtec.
But you wont have m@d VTAAAK, so you wont impress the chicks.... LOL
Old Dec 27, 2005 | 08:06 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: (Cuda70)
Invest in a search its free and adds at least 14 to the rear!
turn of your caps lock for christs sake.
Old Dec 27, 2005 | 09:19 PM
Voodooboy520's Avatar
Keep the HF motor. If you boost it you can get at least 200 RWHP out of it.
Old Jan 2, 2006 | 11:16 AM
srt41320's Avatar
Default Re: (Voodooboy520)
bump for not working on monday but anyways how hard would it be to swap a si d16 setup - motor/tranny/ecu? or is there more?
9,000rpm-b16
Classic Hondas
Sep 24, 2014 05:30 PM
Rease3
Appearance Build Threads
24
Apr 15, 2008 06:39 AM
civicshowracing65
May 24, 2004 05:25 PM
JC19
May 10, 2004 07:36 PM
Speed_Ricer99
Feb 2, 2002 10:47 AM
