GOT HF CRX BODY w/ CRX 1.6 si Motor ( CAR WONT START )!!!!HELP HELP !!!!!!!
Old Dec 25, 2005 | 10:53 AM
xsuperxsonx's Avatar
Default GOT HF CRX BODY w/ CRX 1.6 si Motor ( CAR WONT START )!!!!HELP HELP !!!!!!!
i recently bought a 88 HF CRX BODY , the recent motor had thrown a rod so i just swaped it out and dropped in a 89 crx si engine. I am using the si engine harness the car doesnt get spark , it just laughs refusing to fully turn over ... car gets fuel but no spark !!! makes me really furious i need some crx pros to help me on this one !!!!!
WHAT AM I DOING WRONG ????
Old Dec 25, 2005 | 11:09 AM
91civicEX's Avatar
Default Re: GOT HF CRX BODY w/ CRX 1.6 si Motor ( CAR WONT START )!!!!HELP HELP !!!!!!! (xsuperxsonx)
maybe if you make 3 or even 6 threads more people will help?
Old Dec 25, 2005 | 11:14 AM
FOMULA91's Avatar
Check all the grounding.
Old Dec 25, 2005 | 11:18 AM
Default Re: GOT HF CRX BODY w/ CRX 1.6 si Motor (FOMULA91)
all the grounds are connect everything is in working order , distributor is good , why wont the car turn over ??? is it because the under dash harness for the hf is different then the si harness????
XxdycexX's Avatar
check everything to do with the dizzy.. check the coil ...its old and those are prone to go out...gl luck
-David
Old Dec 25, 2005 | 04:15 PM
Rywire's Avatar
Default Re: (XxdycexX)
Use the hf harness, what is the si harness doing in there!
y-49
Sep 2, 2006 01:55 PM
Rene M
Mar 19, 2006 01:11 PM
