REMOVING FIRE WALL MOTOR MOUNT
Does anyone know what the easiest way is to take off the fire wall motor mount. It looks kind of tricky. Does that mount have any other support arm on it? If I were to take it off would the engines slip a little. Thanks for the help!!
that mount is a pain in the ***.
its easiest to get to from under the car, for most hondas there are 4 bolts, 3 on the engine side, one on the mount side. the eiging will rock backwards but wont drop far, i wouldnt reccomend letting the engine sit like this for too long unless your removing the tranny or somthing. and so you know. its called the transmission t bracket. not firewall mount
GL
GL
