Possible blown head gasket? *PICS*
Old Dec 25, 2005 | 08:10 AM
1SlowSi's Avatar
Default Possible blown head gasket? *PICS*
OKay this motor seems to be an ongoing battle. The first build was fine, when i pulled the head off it showed burn market in between each cylinder. Now im running the same motor, just had to replace the pistons, after 1500 miles or so, i noticed my coolant reservoir always getting low and i have to add to it. At least once a week or so. No leaks anywhere on the motor. I go to pull the valve cover off and this is what i see. I do have head studs, but is it possible that the head is still lifting? As far as the pcv system goes, i just have a tube off the back of the block running down to the ground, and then the breather filter off the valve cover. The car still runs fine. doesnt over heat, and the oil in the pan still looks fine.
nothing like that on the cam caps.
Old Dec 25, 2005 | 08:19 AM
itr1143's Avatar
head gasket for sure.i just went through the same thing for 3300 miles,turbo type r ran great,never run hot,oil in the pan always looks good,rad. always low or res. would be low.but every 6 to 7 hundred miles the oil pressure would start to drop....it is deff. the head gasket....don't for get thr copper spray.
Old Dec 25, 2005 | 08:25 AM
1SlowSi's Avatar
Default Re: (itr1143)
The only thing i can guess is that maybe a sleeve sunk. Cause this has happened on BOTH motors. same block and head.
Old Dec 25, 2005 | 08:30 AM
vtec.dc2's Avatar
Default Re: Possible blown head gasket? *PICS* (1SlowSi)
you could purchase or rent a ooling system pressure test kit.. - with that you will hear where the leak is.. as far as valve cover - breather filter becomes a restriction for ventilation unless you clean/replace everytime after several wot runs. - and causing damage.
Old Dec 25, 2005 | 09:02 AM
DRIVENRacing's Avatar
take the plugs out and turn the motor over.. see if you get water out of the chamber..
Old Dec 25, 2005 | 09:09 AM
Turbo-charged's Avatar
Default Re: (adSPEED)
sunken sleeves seems to be my vote.
Old Dec 25, 2005 | 09:17 AM
kcTurbo4_EG's Avatar
that little goop on yur finger tells me for sure you you probably have a sleeve that has sunk, or depending on what type of sleeves you have coolent might be seeping between the sleeve where they been pressed in the block and dripping into the oil pan. I experienced both problems and it sucks.
Old Dec 25, 2005 | 09:42 AM
SSBPGSR's Avatar
Default Re: Possible blown head gasket? *PICS* (kcTurbo4_EG)
i vote sunk sleeve. if you couldnt seal a head gasket either time, its def a sunk sleeve. get the block milled and perhaps run a thicker head gasket.
Old Dec 25, 2005 | 10:12 AM
1SlowSi's Avatar
Default Re: Possible blown head gasket? *PICS* (SSBPGSR)
i didnt think a benson sleeve would sink. Lemme ask you this. Will i be safe for the meantime if i just change my oil every 1000 miles? cause im seriously not pulling this motor out again. NO WAY! its only got 7k miles on it.
Old Dec 25, 2005 | 10:19 AM
mike93eh
Guest
Posts: n/a
lol ive pulled motors that had 2 miles on them.. do it right or regret it later.
Old Dec 25, 2005 | 10:42 AM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1SlowSi &raquo;</TD></TR><TR><TD CLASS="quote">i didnt think a benson sleeve would sink. Lemme ask you this. Will i be safe for the meantime if i just change my oil every 1000 miles? cause im seriously not pulling this motor out again. NO WAY! its only got 7k miles on it.</TD></TR></TABLE>
If it truely has a sunken sleeve then you have no choice.
Old Dec 25, 2005 | 02:29 PM
1SlowSi's Avatar
Default Re: Possible blown head gasket? *PICS* (Hybrid93Eg)
ya, the only thing i am forced to do, is pull it and send off the block and get them to make sure its freakin 100% flawless. Same with the head. This is bull **** and im tired of it. I would like to start fresh with another motor but that would just cost more. This is just going to take time and hella patience. im glad i have a daily driver.
Old Dec 25, 2005 | 02:44 PM
QuickEJ6's Avatar
Sorry... Next time put the pressure in cooling system before installation
Old Dec 25, 2005 | 02:45 PM
B18C1CYA's Avatar
Well i had a benson sleeved motor and from day one mine was loosing coolant some how , just like you are saying , my oil cap had the same nasty **** on it and under the v/c and i had less than 2400 miles on it , also the sleeve might not have sank but could be leaking at where it go's into the block at the bottom that was my findings , had my head pressure tested twice and put on 2 head gaskets and still the same thing , not mention i had the head skim cut every time the head gasket was changed , now i have a dart block and same part in the cooling system , hoses, water pump, radiator , and heater core , nothing changed just the bottom end , and no coolant issues what so ever , do a search there was another guy with the same problem with a benson block .
Old Dec 25, 2005 | 02:48 PM
88_DX's Avatar
how well did you clean that valve cover from the last time? did it have the same milk shake look to it last time? IMHO if the sleeve sank every thing would look like a milk shake not just the top of the valve cover.
Old Dec 25, 2005 | 02:50 PM
B18C1CYA's Avatar
Default Re: Possible blown head gasket? *PICS* (88_DX)
O yeah another thing just think of your poor main and rod bearings
Old Dec 25, 2005 | 03:00 PM
turbotime's Avatar
sunk sleeve- sux man!
Old Dec 25, 2005 | 06:13 PM
AEBS!
Old Dec 26, 2005 | 03:24 AM
1SlowSi's Avatar
if i changed my oil every 1000 miles shouldnt the internals in fine?
Old Dec 26, 2005 | 05:00 AM
nsxmatt's Avatar
Default Re: (1SlowSi)
Coolant doesn't lube the bearings too well. Don't do it.
Old Dec 26, 2005 | 06:19 AM
mike93eh
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1SlowSi &raquo;</TD></TR><TR><TD CLASS="quote">if i changed my oil every 1000 miles shouldnt the internals in fine?</TD></TR></TABLE>
no
Old Dec 26, 2005 | 06:51 AM
AbitAvenger's Avatar
Deffinently not
Old Dec 26, 2005 | 07:27 PM
1SlowSi's Avatar
Default Re: (AbitAvenger)
well whats your recommendation for the mean time? i mean its really not severe. I changed my oil today and there was NO sign of coolant in the oil. I know u may say fix it or dont drive it now, but i have no time for now. I will in a month or so though.
Old Dec 28, 2005 | 10:03 PM
lucidvtec's Avatar
wow...that sux....don't drive on it
Old Dec 29, 2005 | 04:29 AM
W O T's Avatar
Default Re: (lucidvtec)
Its obivously not recomended to drive on that but yes you can for sure. I drove my D16 for over 8k with milky oil, changed it probably once a month 4-5k and it was fine until i pulled it and built it, never figured out the problem though
