Dream prelude
If cash was not a problem (and yes you still wanted your prelude) What kind of turbo setup would you go. I'm talking the best of the best parts. Please list them.
[Modified by prelude10, 9:33 AM 3/18/2002]
-KIWI manifold (do they still make them?)
-Tial WG
-Apexi IC & custom IC piping.
-Apexi Twin Chamber BOV
-Top quality IC hose fasteners (not the little sissy ones)
-Apexi N1 turbo canister with 3" custom cat-back piping
-Highflow Cat (Not Random Carsound I think its called)
-The most "plug-and-play" standalone system that can be installed with minimum fuss
-550cc injectors
-255L fuel pump (one of the quiet ones)
-fuel lines
-Fuel systems are not my strong points
-Golden Eagle Sleeves
-9:1 JE pistons and JE rings
-Crower rods
-stainless valves
-turbo cams and cam gears maybe
-Clutch good for 400 HP
-lightweight flywheel
-Quaife LSD
-Quaife 6 speed sequential tranny
-DSS driveshafts
-EBC (Electronic Boost Controller)
-guages and stuff
-fuzzy dice
I'd keep it N/A, but I'd invest money, and a lot of it, in other important places!
99 Base w/:
Quaife LSD
Fidanza 7lb. Flywheel
Exedy clutch
Mugen header
exhaust [pick one]
tein ha's
strut tower bars front and rear [spoon]
mugen fg360 steering wheel
mugen c/f bucket seats
takata harnesses
titanium roll cage
various sets of wheels and tires
professional corner weighting
all sound deadining material removed
no cats
11.2: 1 compression w/ type s pistons and spoon headgasket
tarox/AP/spoon racing calipes
ss lines
and, here is where the dreaminng begins:
titanium or beryllium body panels: hood, fenders, doors, trunk lid., all support members and bumper support made from the same material
That's all, altough, for the cost of the body panels, inlcuding R&D and manufacturing, and maybe materials, I could probably buy a newer NSX.
[Modified by bb6h22a, 4:30 PM 3/18/2002]
99 Base w/:
Quaife LSD
Exedy clutch
Mugen header
exhaust [pick one]
tein ha's
takata harnesses
titanium roll cage
no cats
ss lines
j/k
would this happen to be the same blue shadow from preludeonline?
whats up?
made up your mind yet?
whats up?
yes it's me. I think I will eventually go with the Greddy kit ane E-manage. then eventually I will upgrade the internals, raise the boost then upgrade the fuel system and swap WG's then raise the boost some more.
That was just my "dream" setup I posted on here.
thats funny you have that set up blue shadow, because thats the set up im plannin to go lol!. Already have the motor setup on 9:1 arias pistons, just bought the apexi gtr core, etc. I'll send pics when i finish
Apexi is the shiznit! It'll be cool to see your setup once it's complete. keep up the good work!
-Garrett T3/T4 or Turbonetics T3/T4 (bleh!)
-Tial WG
-550cc injectors
-fuel lines
-Crower rods
-stainless valves
-Quaife LSD
-DSS driveshafts
-guages and stuff
-fuzzy dice
-Tial WG
-550cc injectors
-fuel lines
-Crower rods
-stainless valves
-Quaife LSD
-DSS driveshafts
-guages and stuff
-fuzzy dice
I will go with custom hytec manifold
BLUE SHADOW---
i made my decision... tell me if you have any reccomendations....
well, i got the f-max kit and i ordered the r-Ideal head gasket and something new they had called the 6ALBTM-- its a MSD ignition AND the MSD Boost timer, so im spending a lot of money to make sure my ****'s reliable. Then on top of the kit im getting a motec (hopefully) to keep everything in order.... then after all that im putting in some pistons, rods, sleeves, etc.... to be on the safe side, and in case i wanna raise the boost level... what do you think? any suggestions?
by "trim" I meant size, I think that FMAX will let you pick your own size Turbo. The size depends on how much PSI you plan to boost.
average size for a H22 with 8-15 PSI is T04E 57 trim or a 60 trim COMPRESSOR and usually people use a T3 with .63 a/r TURBINE.
click this link to see the boost characteristics of a T3 .63 a/r TURBINE.
https://honda-tech.com/zerothread?id=147072
EDIT: The T04 "E" compressors come in 6 trims.
T04E 40 trim
T04E 46 trim
T04E 50 trim
T04E 54 trim
T04E 57 trim
T04E 60 trim
[Modified by BlueShadow, 7:29 AM 3/20/2002]
T04E 40 trim
T04E 46 trim
T04E 50 trim
T04E 54 trim
T04E 57 trim
T04E 60 trim
So what about the T4/T3B, Super V, Stage 3, .63 A/R that comes with the DRAG Gen 2 Kit for the Prelude Vtecs? Is this turbo any good? What's the maximum boost one can run on this turbo and still be efficient?
99 Base w/:
Quaife LSD
Exedy clutch
Mugen header
exhaust [pick one]
tein ha's
takata harnesses
titanium roll cage
no cats
ss lines
99 Base w/:
Quaife LSD
Exedy clutch
Mugen header
exhaust [pick one]
tein ha's
takata harnesses
titanium roll cage
no cats
ss lines
C-Murdock
Aug 17, 2003 02:06 AM
C-Murdock
Apr 30, 2003 06:21 PM
seanjohn81
Apr 23, 2003 02:37 PM
J2turbo21
Dec 29, 2002 06:04 PM
