Help with Butterfly Valve
I have searched several times and have come up empty...
if anyone can point me in the right direction if a link already exists it will be greatly appreciated...
but otherwise... im tryn to figure out how to eliminate the butterfly valve so when vtec kicks its all at once...
Please and thank you for any and all suggestions except for expletive people who are jus ignorant as hell!
you have alot of searching to do pal. you also better watch who you call ignorant because right now, your the only one looking "ignorant".
1st off, leave the butterflies in. unless you have supporting mods such as cams, headwork, etc...it wont be worth it and you will actually lose power. your also much much better off just getting a different manifold. blox, skunk 2, endyne, etc....all of these manifolds are single runner manifolds, mainly helping top end power. and as i said before, depending upon your supporting mods, you will probly lose power.
2nd, the butterflies have nothing to do with vtec. vtec has its own separate system controling the engagment of a second set of camshaft lobes...that is vtec. the secondary butterflies in your stock manifold are based upon a different system with their own purpose. they help make low end torque and greatly imporve drivability during normal cruising. these open at 5600 while vtec, based upon all the parameters being met, engages at 4400.
so w/ Blox manifold you will lose power, unless you swap the ecu to OBD I, correct. this is where you avoid the dips on the dyno as well as avoiding those damn CEL's. at least that is what i have gathered. correct me if i am wrong. i am also ignorant
i also want to know how to eliminate the secondaries as well. I've read that some honda-tech members were able to lower their 1/4 mile time a little, im not sure if thats true but thats what i've been reading. There is a way to zip tie the minifold to be "open" at all times but i dont know what to zip tie. Thats what i want to test out
You guys are really something. If your racing, the butterflys will be open the whole time, taking them out will do nothing. On a stock gsr, obviously its getting more air low end then it needs, so butterflies were the answer.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oldschooldohcer »</TD></TR><TR><TD CLASS="quote">i also want to know how to eliminate the secondaries as well. I've read that some honda-tech members were able to lower their 1/4 mile time a little, im not sure if thats true but thats what i've been reading. There is a way to zip tie the minifold to be "open" at all times but i dont know what to zip tie. Thats what i want to test out
u can leave em open by disconnecting the vacuum hose from IAB box connecting to the manifold's nipple but i dont recommend it
</TD></TR></TABLE>u can leave em open by disconnecting the vacuum hose from IAB box connecting to the manifold's nipple but i dont recommend it
the IAB are open when they are in the down position. you can keep them open by taking off the vacume line that goes to it, but its going to leav you with a vacume leak.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delLudeVTEC »</TD></TR><TR><TD CLASS="quote">You guys are really something. If your racing, the butterflys will be open the whole time, taking them out will do nothing. On a stock gsr, obviously its getting more air low end then it needs, so butterflies were the answer.</TD></TR></TABLE>
Don't that only open at 5750 rpms?
</TD></TR></TABLE>the IAB are open when they are in the down position. you can keep them open by taking off the vacume line that goes to it, but its going to leav you with a vacume leak.
I was using hondata s200 on a p28 which doesnt control the secondaries. So we unpluged the vacuum line and plugged it up but we lost hp in the midrange because of this!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRVTEC1 »</TD></TR><TR><TD CLASS="quote">
u can leave em open by disconnecting the vacuum hose from IAB box connecting to the manifold's nipple but i dont recommend it</TD></TR></TABLE>
does anyone have a diagram pointing us that vacuum line?
i have supporting mods and am runnin obd1 cause its a 94... jus answer the question not suggest what i should do... jus explain how to eliminate the butterfly valve...
plus my buddy did this and gained... it all hit at once and didnt ease in... soo i kno it will help... his car pulled like a **** stock!
to answer everyones questions.....
first-
the butterfly plate is completely removable if you take the manifold off.....you take out the bolts remove the center plate with the butterflys and bolt it back together...
its pretty much a waste of time.....
second....
on the driver side of the manifold there is a vac hose you can remove and they will be open all the time...this will not create a vaccuum leak as long as you plug the hose.
3rd
the secondaries are open until they see vacuum...thus pulling the hose off.... they will remain open.
the people that zip tie the valve are tieing it shut....god knows why....
there is a canister under the intake manifold with an electric switch that opens them at 5800 rpm
first-
second....
3rd
99black_em1
43
Mar 3, 2009 09:27 PM
xxmikexx206
Aug 23, 2006 03:35 PM
butterfly, diagramcom, gsr, intake, integra, manifold, performance, secondary, skunk2, test, vacumeline, valve
