KBY AGX and ____ spring...
Old Dec 24, 2005 | 11:06 PM
Tuesdaynightfever's Avatar
Default KYB AGX and ____ springs...
Hey guys, I currently have a set of kyb agx's on my 00 hatch that are paired up with a set of mediocre coilovers that I told were fantastic Anyways, I was wondering what type of springs some of you guys were using with your AGX's that have a nice and smooth ride. Pictures would be great also TIA! and Merry Christmas
Old Dec 24, 2005 | 11:07 PM
foam's Avatar
Default Re: KYB AGX and ____ springs... (Tuesdaynightfever)
I'm in the same boat as you. I have some pretty crappy coils that came with the car with AGX Shocks. Is there any decent priced ones out there that won't break my bank?
Old Dec 24, 2005 | 11:12 PM
My coilovers aren't too horrible, but there is a little more bounce than I would like on the highway. I know whenever you lower your car on a budget suspension there will be some bounce, but I'm sure the AGX's are capable of a smoother ride if paired up with the right springs.
Old Dec 24, 2005 | 11:18 PM
JDMSiGuy17's Avatar
Default Re: (Tuesdaynightfever)
i am running my si on agx's and eibach sportlines and they run pretty good!!
Old Dec 24, 2005 | 11:25 PM
pumatec8's Avatar
i have some sprint springs and agx shocks...no complaints here either
Old Dec 24, 2005 | 11:34 PM
RTI's Avatar
RTI
Default Re: KYB AGX and ____ springs... (pumatec8)
I have AGX's on an EG with ground controls. Those of you with generic springs, do you know what the spring rates are? I have tried different spring rates and have yet to find a combination that is bouncy. Most cars that have decent shocks and still have a bouncy ride is because the car is lowered too much for that particular spring rate. This causes the shock to bottom on the bump stop or bottom out completely if you don't have bump stop.
Old Dec 25, 2005 | 01:50 AM
Thanks for the replies guys.
Well I don't have my bumpstops in. I'm pretty sure I never bottomed out either. Most people I have talked to said if you bottom out a shock, you will know it...and I'm really not sure, so I'm guessing I never bottomed them out. Either way, I'm pretty sure my cheap-o coilovers are what is causing the bouncing, because my car isn't all that low yet.
Also, jdmsiguy and pumatec do you have any pics of your car with the drop?
Old Dec 25, 2005 | 05:06 AM
alleyezonme's Avatar
i have the agx's on ebay dropzones (they are like 80 bucks) with 450f 350r. I think it holds up just fine. I have them set on 4 (highest settings for EG) and it kinda compensates for the shitty springs. I bought the springs for an integra though because of the heavy beast under the hood
Old Dec 25, 2005 | 06:27 AM
I-have-an-STD's Avatar
AGX's mated with neuspeed race springs. My opinion, the closest to stock (meaning little bounce) you can achieve, while still having a tight, stiff suspension.
Old Dec 25, 2005 | 06:38 AM
iceman24's Avatar
i have my AGX with a set of tein sports and it is awesome
Old Dec 25, 2005 | 07:46 AM
Any pictures so I can get an idea of how low the neuspeed and tein's lower the car? Thanks guys!
Old Dec 25, 2005 | 08:21 AM
Free-Q's Avatar
I have B+G springs on my 96 accord with AGX dampers, and I am quite pleased had them for about 3 years and they still perform great.
Old Dec 25, 2005 | 10:17 AM
hondaboy4life's Avatar
Default Re: KYB AGX and ____ springs... (Free-Q)
I have ground controls with my kyb agx's, and their amazing. If you want smooth ride u should even really be lookingg at aftermarket suspension. just stick with stock. But if u want wicked sick handling i would sudjest the kyb's with the ground control coilovers. U get used the the stiffness tho.
Old Dec 25, 2005 | 10:38 AM
Caveman74's Avatar
My AGX'S are in the mail!. Getting rid of the crapzones. But I think I will stick with there coilover springs for now, until I can get more cash!
Old Dec 25, 2005 | 11:06 AM
Lmgrcivic's Avatar
Default Re: (Caveman74)
I have AGX's with Tein springs on my EG but the shocks and the springs are for the DC so its alittle bit stiffer.
Old Dec 25, 2005 | 11:26 AM
Spoolinator's Avatar
I Got dose farkin' AGX's on my CTR(96). Dey snuggle 2gether with sKunk2 coils..............I hope you like the sound of my S2k exhaust.... 'cause I'll lose you down any Kool-*** road!......They don't jump on the high-way either.
Old Dec 25, 2005 | 02:04 PM
Default Re: (Spoolinator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaboy4life &raquo;</TD></TR><TR><TD CLASS="quote">If you want smooth ride u should even really be lookingg at aftermarket suspension.</TD></TR></TABLE>
I must agree with you. I'm not asking for a perfect suspension though, I'm just looking to reduce the bounce while on the highway. I figure I have the AGX's already, I might as well get the most out of them.
Thanks for the replies guys!
Pictures are welcomed
Old Dec 25, 2005 | 02:07 PM
ABK's Avatar
ABK
I rock skunk2 coils (integra rate) with AGXs, rides and handles really good. Two of my friends are rocking Ground Controls (integra rates) with AGXs too, rides and handling are comparable.
Old Dec 25, 2005 | 02:39 PM
I'm sort of aiming more towards lowering springs than coilovers, but thanks for all the replies!
Old Dec 25, 2005 | 02:55 PM
turbotime's Avatar
Ground controls are IMHO the very best you can get.
Its a coilover system and you can by custom springs to fit your application or off teh shelf models.
Keep in mind AGX's cant be lowered more than 1.25" without voiding the warranty, it might even be less than that.
All in all AGX are a good entry level strut, but if you want to go low and maintain a good ride you need a better strut- i personally am switching from agx to koni yellow.
Also, I recommend the ground control upper mounts to extend shock travel and the life of your strut.
Old Dec 25, 2005 | 03:42 PM
I know, but like stated before I'm in no position to buy a crazy suspension setup, but at the same time I know my agx's are capable of a less bouncy ride than I have with these cheap-o coilovers. Just looking for people that are happy with their agx's and ___ springs.
Thanks for the replies though. I'm pretty sure I will upgrade my upper mounts when I change over to springs. Anyone know a site that sells these at a reasonable price? I believe it was eibach that I saw for $11 each before. Very reasonable.
Old Dec 25, 2005 | 04:00 PM
mikeunreal's Avatar
H&R Sports Springs all the way!!!
Old Dec 25, 2005 | 04:05 PM
Any pictures of the drop? I was aiming towards H&R race springs, but I'm afraid that the drop might be too low for the horrible roads in good ol' Pennsylvania.
Old Dec 25, 2005 | 04:19 PM
mikeunreal's Avatar
race springs are real stiff, if you use your car as a daily driver get sport springs. its about a 2 inch drop all the way around. looks clean.
Mike
Old Dec 25, 2005 | 04:59 PM
Default Re: (mikeunreal)
Do you have pics of your car on the sport springs? I was debating getting h&r springs before. I've heard nothing but good about them.
