f20b in 91 da9
Old Dec 24, 2005 | 10:23 PM
93 ferio geezer's Avatar
Default f20b in 91 da9
does anybody if this swap even possible. also if not will it fit in a 93 civic 4 door. any help is greatly appreciated
Old Dec 24, 2005 | 10:25 PM
MJobe's Avatar
Default Re: f20b in 91 da9 (93 ferio geezer)
why would you even think of a thing like that......im sure it is possible anything is possible it just depends on how much moola you have and whos doing it
Old Dec 25, 2005 | 03:56 AM
ProjectLSVTEG's Avatar
Default Re: f20b in 91 da9 (91 jdm ls)
IMO one of the most pointless swaps ever, for the money, better could be had.
Old Dec 26, 2005 | 07:25 PM
Default Re: f20b in 91 da9 (ProjectLSVTEG)
ok then how about a b20 vtec in the 91 teg is that better it already has a b16 but it feels like its on its last limb thats why i want to do the swap
Old Dec 26, 2005 | 07:29 PM
also would all i need for the b20 vtec swap is just slap the b16 head on the b20 block and it will all work fine srry about sounding so dumb but this is my first car build thanx
Old Dec 26, 2005 | 07:46 PM
KhanhCord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjectLSVTEG &raquo;</TD></TR><TR><TD CLASS="quote">IMO one of the most pointless swaps ever, for the money, better could be had.</TD></TR></TABLE>
i dont quite agree on being "the most pointless swap ever" ..it's just like swapping in a h22 but weights less.. if u can swap in a h22 then u can swap in an F
Old Dec 26, 2005 | 08:01 PM
Wayne_Curr's Avatar
Default Re: f20b in 91 da9 (KhanhCord)
Theres more machining work that is required on doing the hybrid Vtecs like the b20. You can have a machine shop do the work if you dont know how to work a tap/die
Old Dec 26, 2005 | 08:20 PM
Default Re: f20b in 91 da9 (Wayne_Curr)
lookup ls/vtec, b20/vtec, ls-v, and you will find tons of info on it with the search function and it would be cheaper than an f20b... plus you could utilize a lot of whats already under the hood!, no cutting/welding. And the only wiring you'd have to do is very simple. Anyone with a brain can figure it out. Not to mention parts would be cheaper/easier to find.
Old Dec 26, 2005 | 11:36 PM
KhanhCord's Avatar
thats true... stick w/ the Bs ... much MUCH more parts available than the F and cheaper
Old Dec 28, 2005 | 11:53 AM
b20powereDA's Avatar
i want info on this also. if i read correctly, he asked if it was possible he didnt ask if the b series was more logical. sure the b series is more logical cause its cheaper and more aftermarket support and just about any other benefit u can consider. but i jus wanna know if its possible and if so what has to be done in order for it to work?
Yuta
Sep 24, 2018 12:37 PM
97G_TechLX
Oct 2, 2011 08:30 AM
yomammaisafreak
Apr 13, 2006 08:48 AM
Spectrum24x
Dec 22, 2004 05:52 PM
Friedenreich686
Oct 17, 2004 10:47 PM
