Reducing the compression from 12.5 to something more streetable?
Old Dec 24, 2005 | 09:49 PM
EF8KiLLaBeE's Avatar
Default Reducing the compression from 12.5 to something more streetable?
I have a GS-R motor with 12.5 compression JE pistons, I want to know what would be the best route to go with lowering the compression to around 11.1-11.5. If I use two head gaskets where would my compression be? Or am I better off swapping pistons?
Old Dec 24, 2005 | 10:02 PM
dinko's Avatar
Default Re: Reducing the compression from 12.5 to something more streetable? (EF8KiLLaBeE)
Swap pistons
http://www.c-speedracing.com/h...c.php
Old Dec 24, 2005 | 10:08 PM
Tad's Avatar
Tad
so whats so unstreetable about ur current setup?
seems to me high compression means lots of $ spent on tuning, and poor gas mileage.
but why wouldn't you be able to drive it on the street?
A big cam would be more troublesome in my mind, lopey idle and all
or a featherweight flywheel, making it alil harder to work ur clutch.
Old Dec 24, 2005 | 10:23 PM
92TypeR's Avatar
FSAE
Default Re: (Tad)
12.5 is the perfect compression for pumpgas for an all motor car.
If you use a larger cam, you bleed off a lot of the compression, which allows you to have a little more tuning flexability.
What cams are you using right now?
Old Dec 24, 2005 | 11:41 PM
HondaIntegraR's Avatar
Default Re: (92TypeR)
don't swap pistons, just use a thicker hg, like cometic
Old Dec 25, 2005 | 03:59 AM
I got the motor from a freind who owed me some money. HE had toda b specs in them with the valve springs and retainers. He took the B specs out and sold them. I thought a compression of 12.5 would be too high on pump gas and the idle was lopey, but made good power. I plan on taking my ls/vtec out of my eg and throughing in the GSR instead. So should I just keep the 12.5 compression and get another set of toda B specs?
Old Dec 25, 2005 | 08:34 AM
92TypeR's Avatar
FSAE
Default Re: (EF8KiLLaBeE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF8KiLLaBeE &raquo;</TD></TR><TR><TD CLASS="quote">So should I just keep the 12.5 compression and get another set of toda B specs?</TD></TR></TABLE>
Yes, or something different.
Look into the Skunk2 Pro-2, those would be ideal for that motor setup.
Old Dec 25, 2005 | 12:26 PM
B18 CYA's Avatar
im going to be running 13.5:1cr on the street with toda spec c's, its all in the tuning dude, obviously with my cr i cant use it to the full potention on pump gas, but im getting 2 chips burned, 1 for pump one for race gas, so i can just put in some fuel and swap chips and go!
Old Dec 25, 2005 | 01:50 PM
Tornadom's Avatar
I was worried about running an 11.3 cr, but my friend has a b18c-1 with a 12.5 cr and does okay. He has his motor tuned pretty well, however, as mentioned before, race gas key to realizing the full potential of that setup.
Old Dec 25, 2005 | 07:20 PM
wildoutwhitegsr's Avatar
Go with whatever the tuner in your area is comfortable tuning.
Talk to him to get a better idea and he can reassure you for anything thing you need to know about your compression. That's because that's what it all comes down too.
Old Dec 25, 2005 | 09:19 PM
Michael Delaney's Avatar
Default Re: (HondaIntegraR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaIntegraR &raquo;</TD></TR><TR><TD CLASS="quote">don't swap pistons, just use a thicker hg, like cometic</TD></TR></TABLE>
why the hell would you want less quench area by doing that?
what cams are you running?
what ecu program are you running?
Old Dec 28, 2005 | 06:08 AM
Default Re: (wildoutwhitegsr)
A recognizezble shop I have around here is kingmotorsports( sole distributor of mugen for the us) Once I get everything together I'll have them tune it.
realis9
31
Apr 3, 2007 06:13 PM
rudebwoy
May 24, 2005 01:30 PM
mrduque
Apr 24, 2003 10:17 AM
sushibug
Apr 3, 2002 05:04 PM
Kellindal
Dec 22, 2001 07:38 PM
