How to rethread?
Old Dec 24, 2005 | 08:18 PM
P@@RB@Y's Avatar
Default How to rethread?
I bought a used Ignalls camber kit and part of the thread are worn down a bit.I dont know if this will jurt the adjustability of them or not.Is there a way to rehtread them or just and ol' machine shop job?
Thanks
Old Dec 25, 2005 | 04:40 AM
silentdaredevil2's Avatar
internal or external threads?
Old Dec 25, 2005 | 07:11 AM
P@@RB@Y's Avatar
Default Re: (silentdaredevil2)
My bad external.
Its not all the threads just maybe 1/4 inch in the middle of the camber kit screw.
Also there missing the bolts for the end.Are they regular bolts you can buy at a hardware store?
Old Dec 25, 2005 | 08:50 AM
P@@RB@Y's Avatar
Default Re: (P@@RB@Y)
Heres where the stripped part is.I know its a bad pic of the damage.
Old Dec 25, 2005 | 09:03 AM
thermal's Avatar
You can re-die it using the same pitch but that just depends on how worn those areas are. I personally wouldnt use anything but a minimum of stainless or Grade 8 material (in reference to the bolts/nuts)
Old Dec 25, 2005 | 06:47 PM
P@@RB@Y's Avatar
Default Re: (thermal)
You can still see the thread but barely.
So a machine shop is a place that could fix these right?
Old Dec 25, 2005 | 09:12 PM
Importordomestic's Avatar
well you just need a DYE to rethread it. i would bet the Dye would be around 12mm and 1.50 thread pitch, could possiably be 1.25.
Tap and DYE kits are easily available at your local hardware store. you just need to take one of those upper control arms with you and syai needa DYE to rethread this. they should go over to the hardware section and find athe correct bolt that goes with it then pull the dye to rethread it.
repairing internal studs is where it gets tricky and time intensive.
drsab2000
Sep 17, 2013 06:49 PM
89ED
16
Jul 28, 2013 08:45 PM
zzzzzsi
Aug 28, 2006 07:10 PM
SiR831
Apr 18, 2006 04:45 AM
jerBEAR
Nov 12, 2005 10:56 PM
