Clear out SRS cel code and get new steering wheel
Old Dec 24, 2005 | 07:33 PM
2.2 teg's Avatar
Default Clear out SRS cel code and get new steering wheel
does anyone know how i can clear out the SRS code and keep it from comming back? my bags are now deployed and i will be getting a air bag tray and a new wheel and quick release. so how can i clear this code?
also, what will i need to remove my stock wheel and put in an aftermarket one, just a quick release and a wheel or what?
Old Dec 24, 2005 | 07:45 PM
2.2 teg's Avatar
Default Re: Clear out SRS cel code and get new steering wheel (importtunerboy)
bump 4 help
Old Dec 24, 2005 | 08:30 PM
2.2 teg's Avatar
Old Dec 26, 2005 | 09:34 PM
2.2 teg's Avatar
bump for answer
Old Dec 27, 2005 | 12:46 AM
JDMxtoMx's Avatar
bump for you, i would like to know the answer to this too.
-Todd-'s Avatar
You need a hub and a sterring wheel, quick release if you want it.
Old Dec 27, 2005 | 12:58 AM
JDMxtoMx's Avatar
what about the JDM Non srs steering wheel?
Old Dec 27, 2005 | 02:30 AM
no2unenolife's Avatar
the only thing i can think of is taking out the srs plug from the back of the gauge cluster
Old Dec 27, 2005 | 11:33 AM
2.2 teg's Avatar
Default Re: (no2unenolife)
anyone know the correct way to do it
Old Dec 28, 2005 | 03:07 PM
dcRay's Avatar
You can't reset the srs light unless you hook everything back meaning, the air bag and a new brain. If you choose to go with aftermarket, do what others are telling you, disconnect the plug in the back of your cluster. Otherwise the light will always come back.
Old Dec 28, 2005 | 03:38 PM
PrinceAli132's Avatar
Default Re: Clear out SRS cel code and get new steering wheel (dcRay)
Maybe you can take out the fuse. But I'm not sure if this can be done or works.
Ali
Old Dec 28, 2005 | 08:10 PM
2.2 teg's Avatar
Default Re: Clear out SRS cel code and get new steering wheel (PrinceAli132)
can anyone comferm this, taking out fuse will do the trick?
Old Dec 28, 2005 | 08:33 PM
astig* DC2's Avatar
just take that bulb out.
Old Dec 30, 2005 | 12:26 PM
2.2 teg's Avatar
Default Re: Clear out SRS cel code and get new steering wheel (k4SP3R)
i dont want the code to keep being thrown so i would like to know, from those of you who have done this w/o just taking out the bulb. if all it takes is to remove the fuse, then i shall do that
Old Jan 1, 2006 | 06:35 PM
2.2 teg's Avatar
Old Jan 1, 2006 | 06:59 PM
dc2nick's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dcRay &raquo;</TD></TR><TR><TD CLASS="quote">You can't reset the srs light unless you hook everything back meaning, the air bag and a new brain. If you choose to go with aftermarket, do what others are telling you, disconnect the plug in the back of your cluster. Otherwise the light will always come back.</TD></TR></TABLE>
WRONG!!!
Use this article bro....
Thank you TeamIntegra.. <u>Reseting SRS light</U>
Old Jan 1, 2006 | 07:42 PM
Finger Lickin' good's Avatar
Default Re: Clear out SRS cel code and get new steering wheel (dc2nick)
or this one.
https://honda-tech.com/zerothread?id=264288
Old Jan 1, 2006 | 10:14 PM
freakasis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2nick &raquo;</TD></TR><TR><TD CLASS="quote">
WRONG!!!
Thank you TeamIntegra.. <u>Reseting SRS light</U></TD></TR></TABLE>
thios just resets it...if you are missing an airbag it will come right back on. and if i read it correctly he will be removing both airbags.
Old Jan 1, 2006 | 11:39 PM
DC4me's Avatar
Default Re: Clear out SRS cel code and get new steering wheel (freakasis)
^^ i second that.. i tried resetting my srs light following the team-integra article because i also have an aftermarket wheel but the srs light still stays on. just pull the srs plug from behind the cluster.
Old Jan 2, 2006 | 07:12 AM
dc2nick's Avatar
read that article again guys. It says it turns it off.
If you followed that article and it didn't work, try it again. it sais in the article it may take a few trys.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MorningZ &raquo;</TD></TR><TR><TD CLASS="quote">Let the car sit for around 10 seconds, replace the SRS Plug into the fuseblock location, and next time you turn on your car you should see the SRS light turn on for a few seconds then go off by itself (in other words, act normal)
I'll note that this took me personally three times to get it right, it probably would have made it easier to have a friend sitting in the passenger seat working the ingition key, but rest assured that the above procedure does work :-)</TD></TR></TABLE>
CrackThatTec45
Sep 4, 2009 07:51 AM
Bloody Hatch
Jan 28, 2009 07:27 AM
bmxpunk
Jul 29, 2008 07:28 PM
B20EF
May 3, 2008 09:17 PM
samagon
Apr 30, 2002 05:23 AM
