main relay clicking...no start
hi i own a 93 prelude si and the car out of the blue decided not to start. the check engine light comes on and the main relay clicks on and off very fast. i replaced the relay with no such luck. the car turns over but wont start...i believe its not getting any fuel because i can't hear the fuel pump coming on but it is getting power when i jump the relay. are there fuses for the pump and if so where are they located? Any ideas would be very helpful thanks.
So the pump will only kick on when you jump the relay? Which pins are you jumping? The solid yellow wire on the relay is the one that goes to the pump, if you have a multi-meter/dvom you can check that wire for continuity from the relay to the pump, and also make sure the ground for the fuel pump is good.
i checked for continuity and everythign was good i jumped they yellow wire to the black with yellow i also unplugged the pump and checked the power going to it and it was fine which has me puzzled and it is grounded properly. it almost seems like the problem is beofre the main relay becuase when i turn the key the main relay goes crazy clicking on and off. if anyone has anymore ideas that would be great
no everythign else seems perfectly fine its turns over as normal but nothign happens except the clicking of the relay. i also found that when i put my foot on the brake the clicking changes patterns or sometimes stops.. im running low on ideas of what to do next
I can email you the wiring diagram if you want, you must have a wiring problem before the relay. I hate gremlins like this!
LOL Got the same problem on a '91 AWS , i thought it was starter problem (and i believe it is) checked continuity and got open' all over getting it in my mech next week will post pro's result
cheers and merry x-mas
ok apparently there is a fuse (#23) thats under the dash but the numbers only go up to #20 its located in the srs fuse block... Any idea of where that is located?
boosteddohczc
10
Jun 11, 2009 09:57 PM
insomniac791
Jan 22, 2004 04:23 PM
