Check eng. code after adjusting valve lash.
Old Dec 24, 2005 | 05:49 PM
Default Check eng. code after adjusting valve lash.
I just adjusted the valve lash on a 01 GS-R. I did it to spec. For some reason the car poped a trouble code. Any body have any idea why?
Old Dec 24, 2005 | 05:53 PM
suzawa94's Avatar
Default Re: Check eng. code after adjusting valve lash. ("93XSi")
if you fucked up on adjusting the valve lash it shouldn't set a code. pull the code and see what it is first, then go from there.
Old Dec 24, 2005 | 09:22 PM
blkb18's Avatar
if you adjusted the valves too tight you may be misfireing, make sure your not throwing po300, 301, 302, 303, 304 codes. If so readjust your valves, you can burn up a valve by them being too tight. Valves dissipate their heat by properly seating in the valve seat. If too tight they dont close all the way causing low compression which will cause misfires.
Eliot Tapia
May 27, 2019 06:18 PM
truword1
Honda Civic (2001 - 2005)
Mar 5, 2009 04:44 PM
fridaytech
Honda S2000
Oct 25, 2007 09:12 AM
mja2002r6
Oct 2, 2002 04:17 AM
siisgood00
Jan 19, 2002 09:44 PM
