Tranny removal / installation
Old Dec 24, 2005 | 03:19 PM
J.nguyen's Avatar
Default Tranny removal / installation
when the impound removed my tranny and charged me $500 labor ( what bullshit.. i baught the car like that with no "serial sticker" on the tranny ) , do you think they took my starter also? i dont know how to install / remove trannies but i heard when u installing one you have to remove the starter, but removing one do u think they took my starter? what is the process of installing / removing a tranny? ( like stuff i need to know before doing it and things i should do after installing it)
Modified by vietblood129 at 4:41 PM 12/24/2005
Old Dec 24, 2005 | 03:35 PM
puffsef's Avatar
Default Re: Tranny removal / installation (vietblood129)
starter comes off. one of the bolts to it goes through the tranny and into the block.
Axles come out
tranny mount comes out(both of them)
drain the tranny fluid before you take the axles out or you have a mess.
Need an airgun to take the 32 mm axle nut off and to take the castle nut off of the ball joint.
Absolutely dont forget to fill the tranny with fluid after the install. I found that the easiest way to fill it is through the speed sensor hole approx 2.5 qts. honda tranny fluid or 10w30(some people use motor oil but i would use honda fluid).
Old Dec 24, 2005 | 03:41 PM
J.nguyen's Avatar
Default Re: Tranny removal / installation (puffsef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by puffsef &raquo;</TD></TR><TR><TD CLASS="quote">starter comes off. one of the bolts to it goes through the tranny and into the block.
Axles come out
Absolutely dont forget to fill the tranny with fluid after the install. I found that the easiest way to fill it is through the speed sensor hole approx 2.5 qts. honda tranny fluid or 10w30(some people use motor oil but i would use honda fluid).</TD></TR></TABLE>
so do u think they took my Starter when they took my tranny?? when ppl sell trannies does it come with starters ( i highly doubt it ) ?
Old Dec 24, 2005 | 04:05 PM
J.nguyen's Avatar
Default Re: Tranny removal / installation (neo_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neo_ &raquo;</TD></TR><TR><TD CLASS="quote">Dude, wtf..I read about your story previously..Now they took your tranny off?
Get a lawyer.</TD></TR></TABLE>
man, ive been researching and asking around, now i heard that they took my starter too??! so i need to buy a new starter also.. tahts like another bill... WTFFF IS GOING ON MAN THIS FCKING CHRISTMAS FCKING SUCKS BAWLS&gt; WLFJLWJFLWFOWJFWEJFLWEJF WEFM:OWFJ:WE FJOIM FCKING GOING KRAZY AND I HEAR TRANNY IS ALOT OF WORK TO PUT IT AND SO MANY PROBLEMS MIGHT COME UP&gt;.... and http://video.fox6.com/launcher..._ID=5 HAPPEND TO MY HOMIES TOO. MAN I AM NOT ABLE TO TAKE ANYMORE BULLSHIT
Old Dec 24, 2005 | 07:56 PM
Dartanian's Avatar
They probably took the starter since the tranny needs to be installed for the starter to be mounted correctly. They may have just stuck it back in the mounting holes, but I seriously doubt it.
Old Dec 24, 2005 | 08:19 PM
J.nguyen's Avatar
Default Re: Tranny removal / installation (Das Schmoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Das Schmoo &raquo;</TD></TR><TR><TD CLASS="quote">They probably took the starter since the tranny needs to be installed for the starter to be mounted correctly. They may have just stuck it back in the mounting holes, but I seriously doubt it.</TD></TR></TABLE>
wow gay...
EJ6SON
Jun 25, 2008 03:28 PM
evobassfish
Aug 8, 2007 07:21 PM
Kyles ej1
12
Oct 31, 2004 11:35 PM
cr-x si
16
Jun 19, 2003 09:13 PM
navin
Mar 18, 2002 11:28 AM
